Need help w/Granetelli twin 62mm TB install...
Old May 23, 2010 | 12:44 PM
WaltM's Avatar
All...
I purchased a used Granetelli twin 62mm throttle body and installed it. My car is is in "limp" mode. Granetelli tech support sucks and I'm at a total loss on what to do as a next step.
I followed the directions to the letter. The tps doesn't appear to be adjustable, so I cant manipulate the voltage. The only thing that I can think of doing is to update my tune.
All ideas are welcome...
Old May 23, 2010 | 03:15 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
I never installed it when I had it. Did you make sure the spring was is right?
Old May 23, 2010 | 03:40 PM
WaltM's Avatar
Everything went together fine. Got good spring return and fit. But I have "failsafe" and "check engine" errors; don't know where to go from here...
Old May 23, 2010 | 05:12 PM
70MACH1OWNER's Avatar
I see you have a Brenspeed tune. If I were you I would call them to see if they have run into this before. My bet is they have. You may not like their answer but you can believe it's truthful. Ask for Dave or Brent.
Old May 23, 2010 | 05:26 PM
WaltM's Avatar
I see you have a Brenspeed tune. If I were you I would call them to see if they have run into this before. My bet is they have. You may not like their answer but you can believe it's truthful. Ask for Dave or Bret.
That was my next thought. If the answer is a new tune, then I'll be happy to buy it. I just don't want to keep throwing money at it and not see any results...
Old May 24, 2010 | 09:43 AM
Bullitt995's Avatar
Originally Posted by WaltM
Granetelli
There's your problem. Send it back for a refund and buy a different throttle body if you have to have one.
Old May 24, 2010 | 05:09 PM
WaltM's Avatar
Spoke to Dave. I need to...
Reinstall my original TB and take voltage measurements. Then reinstall the Granetelli TB and "move" the TBS to match the voltage on the original. If I can't get it to match, I'll need to remove the guide pin on the TBS so it can be manipulated to match.
I think it's more trouble than it's worth...
Old May 24, 2010 | 06:43 PM
Yeah. It doesn't happen often but I have to agree with Jake (Bullit995) on this one. If you want an aftermarket TB I would stay with Ford TB's. He didn't say that but that is what I read his post to say.
Evil_Capri
Aug 27, 2015 01:08 PM
Detroit Steel
2007-2009 Shelby GT500
Aug 17, 2015 02:29 PM
Hotrodder2014
Aug 13, 2015 08:43 PM
DerekShiekhi
GT350
Jul 24, 2015 05:58 AM
