mystery chirping noise HELP
Old Sep 3, 2012 | 01:37 PM
muscledom's Avatar
ok, once the car warms up there is a chirping noise (it actually sounds like a cricket) eminating from the back half of the vehicle. the noise only exists while the car is rolling unless its very very slow, like less than 5mph. neither the brakes,the clutch, or the e brake have any bearing on the noise. after driving it long enough to get it squeaking, i jacked up the rear end, put it in 4th got it up to like 40 and put it in neutral and shut the car off. no noise...... -_- so now i understand that it only happens under a load. the noise only seems to intensify with rpms, not speed. which leads me to believe that its something to do with the driveshaft, like a u joint. i call to get a price on u joints, and there are none..... wft. anybody got a clue??
Old Sep 3, 2012 | 05:04 PM
B1GP1MP1N's Avatar
I had a similar noise that was actually coming from the exhaust clamp at the axle back. I tightened it but after a few days it would come back. I put lock tight on the bolts on both clamps, and it hasn't come back. Good luck, those noises are the worst cuz it's hard to figure out where they are coming from.
Old Sep 3, 2012 | 06:13 PM
muscledom's Avatar
Yea I'm thinking that may be it. I recently added longtubes so hopefully it's just a clamp or hanger or something. Thanks for the input!
Old Sep 10, 2012 | 08:41 PM
Cavero's Avatar
Definitely sounds like an exhaust leak. This was mine with a cracked catalytic converter.
Best way is to get under the car and pinpoint it
Old Sep 11, 2012 | 05:49 AM
muscledom's Avatar
Thanks guys. Since I tightened the clamps she's hasn't *****ed a bit lol
Old Sep 11, 2012 | 05:40 PM
B1GP1MP1N's Avatar
Glad to hear you fixed it. Those noises can be a pain in the azz!
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Mr. V
Dec 24, 2016 02:57 PM
ricky1728
Feb 11, 2016 07:25 PM
Rando
Sep 30, 2015 12:28 PM
