My car's CEL is on
Old Jun 27, 2008 | 10:45 AM
LordBritish's Avatar
My car's CEL is on
Does anyone know of a good affordable OBD II code reader?
I have no clue what's wrong.
Old Jun 27, 2008 | 11:10 AM
05GT-O.C.D.'s Avatar
I lust for a M24
Can't answer your question directly, but if you want to save the expense many auto parts stores in my area will hook up a scan tool and give you the results for no charge.
Old Jun 27, 2008 | 02:20 PM
Mojave Dave's Avatar
I saw a display at Advance Auto that had ODBII readers for about $50. Good luck.
Old Jun 27, 2008 | 10:07 PM
My car is still under warranty so I guess I could take it to the dealer have them pull the code - for free I might add.
My car has been modded a little so I'm not sure how they would take that.
Anyhow, it just came on one day. I reflashed it with my SCT XCalibrator I but the **** CEL still comes on after a while.
Old Jun 28, 2008 | 06:16 AM
I lust for a M24
Can't you read the code w/ your X-cal? I know if it's an X-cal 2 you can.
Old Jun 28, 2008 | 09:50 AM
70MACH1OWNER's Avatar
Ditto!
Old Jun 29, 2008 | 12:09 AM
I got an X-Cal 1.
So I can't read the codes.
I went to Autozone today and I borrowed a OBD reader.
The code is P0506 - idle RPMs too low.
I did recently change from 5W-20 oil (Amsoil) to 5W-30 oil (Mobil 1).
Do you think that could have lowered the idle RPM ?
Old Jun 29, 2008 | 12:42 AM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
I got an X-Cal 1.
I seriously doubt it, especially not enough to throw a code.
Old Jun 29, 2008 | 12:47 AM
I heard cleaning the throttle body might help.
Old Jun 29, 2008 | 12:48 AM
GottaHaveIt's Avatar
If what could be said mod could be linked to the error, they'll want to charge you or they could even say warrenty is void they may even record it and log it so anywhere you go it';ll show , only mods I go don't effect or I CAN remove befoer I take it to dealership.
Old Jun 29, 2008 | 02:54 PM
Robbieg's Avatar
Does the x-cal 1 have user adjustable parameters? If so double check that the idle rpm's didn't get changed by mistake. I can adjust mine but I'm not familiar with version 1.
Old Jul 5, 2008 | 01:49 PM
I took apart the throttle body and cleaned it out.
It was full of black stuff at the back.
My idle RPMs appear to be higher now.
No CEL light so far since I cleaned it.
Old Jul 5, 2008 | 03:21 PM
Any pictures?
Old Jul 6, 2008 | 09:03 PM
Originally Posted by 2k7gtcs
Any pictures?
No, but it looks like black tar that collect around the butterfly valve. I suspect it causes the valves to not close properly which caused the idle problem.
Old Jul 6, 2008 | 09:06 PM
What kind of mileage did you have on the car, and how old. I'm just curious so that if this ever happens, I'll remember to check this out.
Old Jul 6, 2008 | 09:08 PM
Any pictures?
My car was purchased new around Oct 2004. I have about 28,000 miles on it.
It's very simple to clean and should probably be done routinely.
Old Jul 6, 2008 | 09:12 PM
What did you use. A rag only, or what cleaner? I would think there is some cleaners you would not want used in an intake.
Old Jul 6, 2008 | 11:32 PM
I just used a rag and spit - lol.
Old Jul 7, 2008 | 06:52 PM
Did you purchase an extended warranty? Because by my math your warranty should have been used up about 8-9 months ago!
Scott
Old Jul 8, 2008 | 10:17 AM
SStang's Avatar
I'm pretty sure that would be illegal.
