Motor Mounts?
Motor Mounts?
Does anyone know if they make adjustable motor mounts for 05+ mustangs?
I'd like to be able to drop the engine a little to allow a strut tower brace to clear a supercharger.
How did you cut them square? I've been toying with the same idea--my carbide tipped mitre saw works fine on aluminum, but I want to make sure I get a square cut and they are sort of odd shaped.
I used a compass and traced a line around them that I used as a guide. Then, quite frankly, I cut them one at a time using a bench vise and a (GASP!) Sawzall with a fine tooth blade. Sounds hillbilly (maybe it is?) but it worked fine and they have been on the car for several months including many WOT adventures, and WOT clutch dumps on 325/45 drag radials while pulling the driver's front tire off the ground and running 11.7s.
I get the picture now. The JDM mounts are prothane's that they've trimmed down...JDM wants $185 and indicated a 3/4" drop. I'll by the Prothane's and get a machine shop buddy to trim them down for me.
Thanks everyone for your advice
Ebay - P mounts
I think I'll try and take an exact measurement before removing the stock mounts, then trim the Prothanes to match.
Thanks for the info! I may go that route if I can't clamp then down square in my chop saw.
From what I've gathered, the Prothanes raise the engine about 1/4" compared to stock. This is probably because they are the same height dimension as the stock mounts, but the stock mounts compress down a little when the engine sits on them.
I can tell you that the stock Prothanes will raise the engine about 1/4 inch. And if you want the same height as the stockers you would need to trim that 1/4 inch off of them. I already measured an "unloaded" stock engine mount and it checks the same as the Prothanes but when the engine weight is on the stockers they must squish down that 1/4 inch
Hey Mark,
For a daily driver with no longtubes I would say "NO" but if you go with longtubes you will them need to control engine movment so it doesn't rub the steering shaft or anything else. That is why I did them.
Scott
Thanks Scott.
Tom, did you lower your engine while you still had your Paxton intercooler? If so, did the lower height make a difference in clearance with the pipes?
