Manual Transmission Fluid
Old Oct 27, 2007 | 06:37 AM
ronslakie's Avatar
I have an 07 GT 5 speed and was wondering if the factory installed manual transmission fluid is synthetic. I have installed Red Line Manual Transmission Lube in another vehicle I have and it definitely made a difference in smoothness especially in the winter with really cold temperatures. Has anyone here installed synthetic fluid and has it made a dirrerence?
Old Oct 27, 2007 | 07:59 AM
302svt's Avatar
Deleted. I was thinking about the rear end oil.
Old Oct 27, 2007 | 08:03 AM
anthony05gt's Avatar
I use Royal Purple Syncromax.
Old Oct 27, 2007 | 02:57 PM
MustangRetribution's Avatar
I used Red Line, cant honestly say I noticed a big diffrence, if it was synthetic to begin that might explain it, but I was under the impression it was conventional ah well
Old Oct 27, 2007 | 07:22 PM
06GT4RAD's Avatar
I wouldn't run RP in my lawn mower.
It really is not a very good oil. It continuously fails in independent tests.
They have a very good marketing campaign but that's about it.
By the way isn't the fluid in the manual trans regular ATF or have they finally switched back to a manual type fluid?
Richard
Old Oct 27, 2007 | 07:58 PM
you have where I can find that info on RP? would be interesting to see for myself if you have a link,
I use mobil 1 now but was considering RP.
So far as I know they still use ATF in the manuals
Old Oct 27, 2007 | 08:35 PM
Dysan's Avatar
I contacted Tremtec awhile back and they said it normally does use ATF in it but you can put syncromax in for it to be quieter and a bit smoother but it will be harder to shift in the winter cold until it warms up.
Old Oct 27, 2007 | 10:26 PM
06GT4RAD's Avatar
Here is one for gear lubes that was recently done. There are other on oil but it has been awhile since i read one of those.
http://www.amsoil.com/lit/g2457.pdf
Richard
Old Oct 28, 2007 | 10:01 AM
SP_51-F1's Avatar
I have been runing Syncromax for over a year now. I changed over at 15K miles and the stock fluid still looked fine. I feel that the tranny is a bit quieter now, but I never had shifting problems before or after the switch.
Old Oct 28, 2007 | 10:24 AM
karman's Avatar
Austin doesn't know what winter cold really is.
Try 30 days that never,ever get above freezing.
Old Oct 28, 2007 | 01:18 PM
RadBOSS's Avatar
Fluid recommended and used by Ford is Mercon. In discussion I had with a TREMEC engineer his recommendation was to stick with Mercon. For manual transmissions you do not want a slick oil, as those properties will interfere with the operation / effectiveness of the blocker rings. TREMEC also pointed out that some of the non Mercon oils also have additives that are detremential to the composite material on the blocker ring.
Old Oct 28, 2007 | 07:03 PM
theedge67's Avatar
Stock fluid the car comes with is Mercon, non synthetic. I'm pretty sure though it does not need to be changed over the life of the car. I don't think it is mentioned in the scheduled maintenance.
CiniZter
25
Apr 28, 2016 05:41 PM
mx5jhb
Sep 30, 2015 04:44 PM
Rando
Sep 30, 2015 12:28 PM
Kalel08
Sep 29, 2015 03:06 PM
