Magnaflow Catback Install Question
Old May 4, 2005 | 08:15 PM
RudyUD's Avatar
Tried to post this before, but it didn't work, so I'll try again:
Anyone know if backing the car on ramps will be sufficient enough to install the Magnaflow Catback's? Any input would be helpful.
Old May 4, 2005 | 08:25 PM
ryan1112's Avatar
I just installed Magnaflow Magnapacks and you may have trouble with using ramps. They will be high enough to get under there but you might not be able to get the pipes in and out unless you use jack stands. The suspension needs to be fully extended to get the origional pipes out over the axle. Even then I had to work with the pipes for a while to get them out. Also, the higher you get the car off the ground the better, easier if you can let the pipe hang down some while you are trying to work them out. JUST BE CAREFUL!
If you need any more advice or specific question, just ask. Have fun.
Jim74656
May 1, 2023 02:15 AM
Andy11859
Which is Better
Sep 10, 2015 12:07 PM
tony2014mustang
Aug 9, 2015 03:04 PM
tony2014mustang
Jul 23, 2015 10:56 AM
