Looking for lightweight wheels.
Old 7/5/08 | 11:50 PM
Pwny's Avatar
I'm looking for lightweight wheels for my car. I would like something that is around 20 lbs. a wheel, but I'm open to all sorts of suggestions.
Old 7/6/08 | 08:05 AM
Greywolf's Avatar
gram lights on tire rack or http://www.tirerack.com/images/wheel..._brs_ci3_l.jpg about 20.5 lbs there are lighter ones but much more expensive i also like the steeda pentars but i dont know what they weigh the gram llights come in different colors
Old 7/6/08 | 08:52 AM
Import-Slaya's Avatar
Here you go: http://forums.bradbarnett.net/showthread.php?t=461952
Old 7/6/08 | 08:53 AM
ford4v429's Avatar
legacy Tms Member
I got centerline telstars for our Mark VII and our camaro- very light and at the time fairly cheep- but I think they are kinda pricey now...nice ting is, just about any offset is available
Old 7/6/08 | 09:52 AM
70MACH1OWNER's Avatar
I am running the Steeda Pentars. While they look like they should be lighter going from a 17x8 wheel to a 18 x 9.5 wheel plus the 275 Nitto's I can tell you they are quite a bit heavier than the stock wheels and tires. My guess is 10-15 lbs per wheel.
Old 7/6/08 | 06:43 PM
Pwny's Avatar
I hope I don't get any ricer flak, but I do like the 5zigen and GL's. I'll have to check them out.
Thanks for the help guys.
Old 7/6/08 | 07:32 PM
Both are nice wheels. Plenty of Mustangs in American Iron and American Sedan are using the 5zigens. Very light, but it has proven to be pretty durable.
Old 7/6/08 | 09:37 PM
Pwny's Avatar
That's good to hear. I want to invest in some as I am trying to turn my car into autocross machine!
Old 7/6/08 | 09:56 PM
Pwny's Avatar
P.S. You should post some pictures too
Old 7/7/08 | 06:41 PM
RadBOSS's Avatar
Anyone running the Steeda Q1S wheels?
Old 7/7/08 | 06:57 PM
Pwny's Avatar
I might consider it if I knew how light they were
Old 7/8/08 | 12:48 PM
329VistaBlue's Avatar
I have been researching "lite" wheels for a while now and I can tell you that FORGED are the lightest and strongest. Low pressure cast wheels like Steeda's offer some weight savings over standard cast but will not get you to twenty pounds for an 18 inch wheel. If you are looking to autocross the car and the brakes are not forcing you into a larger wheel I would go with 17 inch forged wheels. They should be a lot less than twenty pounds. Some wheel makers you should look at before you buy are;
Fully customized to your needs and very high end are HRE, Forgeline, and I Forged.
Excellent wheels and more affordable are BBS, and OZ.
If the price of forged is an issue and it is with me which is why I am still saving for mine, low pressure cast is the next best thing and the Steeda wheels offer a great balance of strength and lower weight.
One last thing. The HRE and Forgline wheels I have on my wish list are twenty-one pounds for an 18X9.5
Old 7/8/08 | 12:51 PM
Pwny's Avatar
I'm looking to get the TR Motorsports wheels off of tirerack.com.
Thanks for the info. I think it will be a long time before I can buy a set of forged wheels
Old 7/8/08 | 10:22 PM
TTS197's Avatar
I was thinking of getting these (Volk RE30) Just a little pricey, but not a bad looking wheel.
that's a 17X9 btw, the 18x9 weight is 17.45 pounds
Old 7/8/08 | 10:39 PM
RadBOSS's Avatar
Gus tells me they are about 26 lbs. Nice deep dish looking wheel.
Old 7/9/08 | 11:57 AM
Pwny's Avatar
Too heavy for me!
The Volks are definitely a nice wheel. They look fantastic too.
Old 7/9/08 | 11:56 PM
bob's Avatar
bob
Man, looked up all the fitments for Mustang wheels over at Tirerack and compared weights, the Fanblade wheel is 27 pounds and the Bullitt wheel is 25 pounds, tire weight is around 28 pounds (27 + 28 = 55) So 53-55 pounds of unsprung weight in the stock configuration.
Good to know since I've been mulling a change to 275/40R18's with wider rims that can fit the GT500 brakes and I'm not really interested in borking the unsprung weight with the FR3 suspension on the car (it was setup with these weights in mind).
Old 8/30/08 | 06:18 PM
jedikd's Avatar
I've got a set of Asa AR1s going on soon from tirerack. Website says they're about 23 lbs for a 18x9, which ain't too bad for a wheel that goes for $172 a piece.
Old 8/30/08 | 10:15 PM
LEO_06GT's Avatar
The Ford GT wheels weigh in at 17lbs and look really nice on the stang. A TMS member with the handle of Lokius runs that setup and it looks friggin bada$$.
Old 8/31/08 | 09:07 AM
No still shots, but here are three from the track.
Attached Thumbnails Looking for lightweight wheels.-vir-pic-1.jpg   Looking for lightweight wheels.-vir-pic-2.jpg   Looking for lightweight wheels.-vir-pic-3.jpg
