Looking for better handling.
Old Oct 6, 2012 | 01:28 PM
n8tv's Avatar
I have a 07 gt. I have stock 17's on it with Pirelli tires. The problem I have is in corners or when accelerating out of a corner my back end slides out very easy. I bought the car used with 20,000 miles on it so the tires are still good. Would I better to get new tires , I was looking at getting the 20" shelby razor tire and wheel combo from American muscle or lowering my car and adding new sway bars. I already have the strut tower brace. Thanks for any replies.
Old Oct 6, 2012 | 01:40 PM
s197's Avatar
I would go with the same setup that American muscle went with on there handling package on the bolt on build up on their site I believe it's the best for the money and you should not be disappointed I love taking corners now
Old Oct 6, 2012 | 01:46 PM
s197's Avatar
On the back wheels I would also go with at least go 10 inches wide or wider so you can Maximize your traction
Old Oct 9, 2012 | 08:46 AM
AMDanBailer's Avatar
Former Vendor
n8tv,
It's pretty common for a 300 hp V8 to let the rear end slide out a bit on stock suspension! I would recommend getting a set of Sway Bars, Some sort of lowering either Springs or Coil overs, and a pan hard bar. This will transform your Stang into a fish tailing animal, to a full on road course beast! We also offer handling packs, Definitely check them out.
As far as rims go, it really depends what you would like to get out of it. If your looking for a track car then I'd stay around 17-18's for your rims. Mainly because they're light weight and will allow you to throw the car around a bit!
This is just a few suggestions, let me know if you have any questions! Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
-Dan
Old Oct 9, 2012 | 03:56 PM
n8tv's Avatar
Originally Posted by AMDanBailer
n8tv,
-Dan
Thanks Dan I have been checking out American muscle packages for the last couple of days. If I went with a 18" rim I could fit a wider tire. In your opinion would it be that noticeable a difference over the stock 17"? Or could I just slap some nitto 555 on there with a handling package and go.
Old Oct 9, 2012 | 04:18 PM
muscledom's Avatar
Dude I just gotta say I love the way your car looks. Ill be blacking mine out around Xmas. I can't wait.
Old Oct 10, 2012 | 09:18 AM
Former Vendor
N8tv,
Yeah the real benefit to running 18's is that you can purchase a wider wheel, which means a wider tire! However when it comes to handling you don't want to run too wide, so it really depends on what your goals are for your Mustang.
A set of sticky 255-275's and a handling pack will put you in really good shape! I hope this helps, let me know if you have any questions. Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266.
-Dan
Old Oct 10, 2012 | 01:07 PM
white08gt's Avatar
i am lowered and running 285/40/18 nitto 555 and they do not hold as good as my stock p zero's unless the roads are hot, they suck in cool to cold weather. changed out my lca's and put a adj. panhard bar also. 2 weeks ago, turning left to get on the interstate, i was in the inside lane and porsche boxster s was on my right and tried to pass before the lane merges and hit it withoutturning off tsc and grabbed 2nd gear and backend came around, corrected and then came around the other way twice before i could get it straight. scared the **** out of me, normally with tsc on it cuts back when the wheels slip but for some reason it did not work, luckily no one was behind me. it happened so fast i don't know if i over corrected both times or what.
Old Oct 10, 2012 | 07:56 PM
n8tv's Avatar
thats good to know cause i was thinkimg about getting those tires.
Old Oct 11, 2012 | 06:48 PM
retfr8flyr's Avatar
Are you looking for an all season tire or summer performance? If it were me I would get a set of 18's with summer performance tires and use you stock wheels and tires for the winter months. If you really want the car to handle well then stay with an 18 inch wheel. When you get into 20 inch wheels, unless you spend a fortune, they are too heavy to perform well. I would check out the wheel and tire packages from The Tirerack also.
Earl
Old Oct 11, 2012 | 07:38 PM
n8tv's Avatar
Yeah I am gonna stay with the 18. I think I will go with a all season cause I will be selling my current wheels to help pay for the new ones.
Automagically
2012-2013 BOSS 302
37
Feb 19, 2020 09:28 PM
TMSBrad
Jan 21, 2010 02:37 PM
classj
16
Jun 6, 2007 09:44 AM
dtoups
Nov 29, 2004 11:42 AM
TMSBrad
Aug 4, 2004 05:59 AM
