Leaking brake fluid.
Old May 26, 2005 | 06:50 PM
mikem's Avatar
Smile
I keep seeing brake fluid leaking from my brake fluid reservoir.Keep whiping it,but always comes back.Tried tightening cover but still appears.cover is leaking. :angry:
Old May 26, 2005 | 07:57 PM
05SatinGT's Avatar
I have noticed same exact thing. It's a fair amount of fluid too.
Old May 26, 2005 | 08:01 PM
mustangshadow's Avatar
i have actually noticed the same thing its not alot but just enough to make you wipe it to keep it clean on the top
Old May 26, 2005 | 08:03 PM
05redfiregt's Avatar
I have also noticed the same thing its not much though
Old May 26, 2005 | 08:17 PM
JST4FN's Avatar
Both my 03 and 04 Cobra did that along with my 05 GT. I never could figure out why but I did not have a problem. Just keep a eye on it from time to time.
Thanks Mike
Old May 26, 2005 | 08:46 PM
2MFF's Avatar
I've noticed it too.
Do you guys have manual or automatic transmissions??
Old May 26, 2005 | 08:50 PM
nbk13nw's Avatar
Me too! With a manual? Why do you ask for the tranny?
Old May 26, 2005 | 09:01 PM
srichard's Avatar
I'm glad I'm not the only one.
Old May 26, 2005 | 09:28 PM
2MFF's Avatar
I'm wondering if it has something to do with the hydraulic clutch (isn't it fed of the same master?)
Old May 26, 2005 | 11:39 PM
cop on my back's Avatar
No, it is not. Mine does it too as well as my 04 Sport Trac. Not sure why? I don't think it is a lot, just looks like it. I think it probably has something to do with the venting of the resivoir.
Old May 27, 2005 | 03:50 AM
AircraftTech's Avatar
Yeah I have the same problem. I'm a hyraulics mechanic in the air force, so I have a bunch of spare rubber seals hangin around. I'm goin to see if it may need a larger seal around the filler cap. If so, and I fix this silly leak, I will post the repair info. If its just a seal, you should be able to buy a seal for under a few bucks at any parts store.
Old May 27, 2005 | 04:53 AM
jerseygirl12's Avatar
Same thing here. It's nice to know this is fairly common. How much should I be worried about it???
Old May 27, 2005 | 06:51 AM
gotmy05's Avatar
I see the same thing, not much but enough to annoy me.
Old May 27, 2005 | 06:56 AM
Auto for me
Old May 27, 2005 | 07:15 AM
BadHenry's Avatar
Count us in, we have the same problem.
Old May 27, 2005 | 08:58 AM
Big Poppa's Avatar
I think it could be the plastic tank and top that causes the the problem. Back in the day when we had the metal tank with the snap over a metal lid I can't remember it ever leaking.
Old May 27, 2005 | 10:23 AM
Burke0011's Avatar
Big Falken Tires
Auto - same problem here too
Old May 27, 2005 | 11:27 AM
05YellowGT's Avatar
I've got the Ford Shop Manual and actually the clutch does share the reservoir with the brakes. However , you might be right about the venting ...
Old May 27, 2005 | 11:33 AM
I don't remember my 03 Vert Gt doing it.
