lca's
lca's
Im getteing ready to buy some Lca's, Im looking at CHE, BMR, Spohn. All look like quality parts and cost about the same the olny diff i see is the bushings in the CHE do not need lubed. Do they squeak after awhile or are they a truly maintanace free part. Any input would be helpful.
The bmr's that I had required grease. The front bearing needed a set of washers due to the incorrect size of the bushing. This was the reason that I sold my pair and switched to another brand. They were a nice build but I didn't like the makeshift setup. When I inquired to BMR on this, that's when they sent me the washers...Wasn't what I was looking for but they must have machined numerous bad setups and this was their fix vs sending a corrected piece. Hopefully they have fixed this problem since then. I think they are probably all comparable (hence the nearness in price)....Just look for lightness and strength capabilities along with adjustability (if you need to adjust---most don't and just want lighter/stronger). I would also recommend lokar Lca's....They are a quality unit from what I have read (but don't actually have)...
