Lca and uca.....
Old Feb 23, 2008 | 11:29 AM
BlackSnakeMoan's Avatar
Lca and uca.....
which one is better to get adjustable? Or should i get them both adjustable?
i checked bmr site and they have a few of them with poly bushing, rod end or spherical bearing. which combination is best?
Old Feb 23, 2008 | 05:07 PM
SONICBOOST's Avatar
Usually its a fixed lca and an adjustable uca... I use the brm billet lca and I love it!
Old Feb 23, 2008 | 07:01 PM
DarkFireGT's Avatar
For most people, an adjustable UCA and fixed LCA's would be the way to go. It's a lot easier to adjust (and get it right) one up top than two on the bottom.
Old Feb 23, 2008 | 07:39 PM
bob's Avatar
bob
I agree, the UCA is the way to go, you can screw the thrust alignment up if your not careful with the adj LCAs
Old Feb 24, 2008 | 01:56 AM
Cool, i think i'll get the uca adj. but what will the lca relocation brackets be used for if i have fixed lca.
Thanks for the useful replies guys(unlike in other forums)
Old Feb 24, 2008 | 03:50 PM
DavidM's Avatar
The relocation brackets are used for cars that have been lowered to correct the suspension geometry. The LCA should angle slightly to the rear of the car. Sometimes after you lower your car the angle actually changes to the opposite and the LCA is pitched forward because the rear is sitting higher in the chassis. Oh and to answer your question about the bushings get the poly ones not the spherical rod ends as those are for hard core racing only.
Old Feb 24, 2008 | 03:58 PM
officespace56's Avatar
So hypothetically...lets say you have some lowering springs and some LCA's and Relocation brackets sitting in yor garage waiting for spring to come. What order should you put the 3 on? Hypothetically
Old Feb 24, 2008 | 04:34 PM
DavidM's Avatar
I would do the UCA first as per the manufacture instructions. then do the RElocation brackets and LCA's at the same time as the LCA's have to be removed anyway to install the relo brackets. At least the rear portion as well as the panard bar.
Old Mar 10, 2008 | 10:07 PM
Stoenr's Avatar
Just going to add my question in vs making another thread.
Mods currently
Roush rear springs
Che Adj. Lca's
Adj panhard.
Pinion angle set by LCA's. 4wh align in specs.
Whats sitting here waiting for warmer weather.
Eibach Pro kit
Dspec's
Lca Relocation brackets.
Since I will be needing an alignment and already be working in the rear suspension area I am thinking of adding an UCA to the list. Am I ok with a non adj. upper since I can change the pinion angle with my lowers?
Occasional drag strip for fun, road track once or twice a year for fun, and daily driver in the summer. Alum drive shaft planned in the future........
Thanks, Im going nuts reading all the suspension threads in many forums
Old Mar 10, 2008 | 10:20 PM
SoundGuyDave's Avatar
You'll be FINE with just the adjustable lowers for your situation. Get a good UCA with a poly bushing and fuhgeddaboudit....
Old Mar 11, 2008 | 03:43 PM
n8rfastback's Avatar
i have a question.....
would it be possible to swap the bushings out on the stock LCA's with poly ones, and strengthen the stock pieces at all???
just wondering, i like to weld, and poly bushings arent that expensive.....
Old Mar 11, 2008 | 07:17 PM
Stoenr's Avatar
Thanks, what I wanted to hear.
Not worried about adjusting thrust angle via lowers and pinion, we have a state of the art alignment machine to do that. If the car will clear the rack after lowering, lol.
Old Mar 13, 2008 | 02:53 PM
mot250's Avatar
Adding stiffer poly bushings to the stock LCA would be an effort in futility if that is all you did (and if it is possible to remove the stock bushing without destroying the end of teh arm??). The stock arms are flimsy, thin, stamped steel pieces. Unless, that is, you want to remove them and box 'em as well. A lot more work than just replacing them but it could be more stealthy than aftermarket LCAs.
Old Mar 13, 2008 | 03:13 PM
yea i was thinking about poly bushings and boxing the stock arms to strengthen them....
DrVet
Sep 23, 2015 01:48 PM
SpeedyJoe
18
Aug 23, 2015 02:42 PM
Import-Slaya
29
Nov 15, 2005 06:52 AM
Cleveland
21
Nov 9, 2005 09:19 AM
Redfire 05Gt
16
Mar 26, 2005 11:49 PM
