Largest tire for stock bullit wheels?
Old Feb 12, 2007 | 10:03 AM
DavidM's Avatar
I am wondering what is the largest tire that has been successfully installed on stock 17" bullitts? Am interested in the back tires more than the front.
Old Feb 12, 2007 | 10:35 AM
FRITZ's Avatar
I think it's 255/50/17
Old Feb 12, 2007 | 02:13 PM
69_gt500's Avatar
Ive heard you can go as high as a 275/45 tire on most 8inch wide rims, although I wouldnt try it.
Old Feb 12, 2007 | 02:29 PM
34124231user's Avatar
No.
255 is the widest tire approved for the factory 17 inch rims. Anything larger is insane. These cars put out 300 hp and go over 140 mph- now you want to roll around on over-stressed sidewalls? If you want wider rubber, you need to buy wider rims.
A reputable tire shop will not install anything larger than 255 on your factory rims, due to laibility issues. A not-so-smart tire shop will put on anything you want. You decide.
Old Feb 12, 2007 | 02:36 PM
DavidM's Avatar
Well I wasn't planning on doing the ricer tango with my tires sticking out a foot on all four corners I was just wondering if anyone else had used the stock wheels with a larger than stock tire. I think the car would look tougher with a slighlty larger rear tire. I think a 255 ratio tire would look a lot better than a 235 20mm larger sounds about right without getting the tread past the lip of the wheel for stability.
Old Feb 12, 2007 | 02:49 PM
69_gt500's Avatar
I found this on another forum http://www.allfordmustangs.com/forum...rformance.html
Old Feb 12, 2007 | 02:53 PM
FRITZ's Avatar
I had 255/50/17s on my '05 GT, i think they look better then the 18s on my GT/CS (as far as the tires go). I do like the 64w wheels on the GT/CS better then the stock 17" wheels.
Old Feb 12, 2007 | 03:07 PM
69_gt500's Avatar
255 IMO is the all around perfect size for stock rims
Old Feb 12, 2007 | 07:26 PM
DavidM's Avatar
Thanks for the info 69 GT500
nismos13s14
1994-2004 V-8
Jul 31, 2015 07:40 AM
