Just to clarify before ordering .... 255/45zr18 front 295/45zr18 rear?
Old Dec 5, 2006 | 05:48 AM
  #41
Hatchman's Avatar
Originally Posted by Redleg
Using the calculator here....
http://www.bigcustomwheels.com/rt_specs.jsp
The 295/45/18 is 1.3 inches taller than the stock 235/55/17 tire. Am I correct in assuming that the 1.3 inch height increase will fill the gap between tire and fender?
I don't want to stuff the tires in there necessary will a big drop.
It's going to raise the rear by .65", and fill the gap by .65". The 295's do a great job of filling the gap, but I think you'll need a little drop or the rear end will be up in the air. I think the rear is already around .8" to 1.0" higher than the rear (depends on car, how much gas, shaker 1000, spare tire delete, etc), with a .75 to 1.0" more of a gap between the top of the tire to the center of the wheel well than the front tire/whell well has, so the .65" of extra tire should fix that. But ow the rear end is going to be about 1.55" higher than the front. Just rough estimates. Even tire pressures could change this a little.
You could always us a jack to jack up the back of your car .65" to see if you like the look. A floor jack and a tape mearsure, this could take only a couple of minutes.
Old Dec 5, 2006 | 07:28 AM
  #42
06GTwJUICE's Avatar
My rear is higher by about 1 inch or more... and the tire fills the gap very nicely. I even think it's a little higher than top of the wheel well opening but no rubbing issues have popped up yet.
Old Dec 17, 2006 | 06:45 AM
  #43
Hatchman's Avatar
I decided to go with the 255/45/18 and 295/45/18 in Nitto 555. I test fit a rear, and the rear was too high for my taste, almost 30 inches! Definitely 4X4 territory. Well, come to find out the rear wheels were 22mm offset, so while I'm waiting on my new ones, I'm reasearching how everyone with 295's in the back with lowering springs are experiencing any rubbing or bottoming out with passengers in the back. I'm thinking about the Roush springs, since they will lower the car rear about an inch and I'm thinking the progressive spring rate will still allow for a close to stock ride normally, but will get stiffer on compression to help prevent bottoming out.
What do you all think?
Old Dec 17, 2006 | 08:47 AM
  #44
06GTwJUICE's Avatar
You will be fine. (i replied toyour pm)
The 295's are a good bit higher than stock with the 45 and gives it that raked look kinda.
it looks nice, drives nice, has nice traction and have no rubbing issues and i'm 1.5inches lower. OH and did i mention it looks nice!!!!!!!
Old Dec 17, 2006 | 09:47 PM
  #45
RadBOSS's Avatar
22mm offset on the rear is not very good choice for this car. You should have at least 35mm's if not more ... unless you like that kind of look with the tires hanging out beyond the sheetmetal ...
Old Dec 17, 2006 | 10:07 PM
  #46
06GTwJUICE's Avatar
I picked up deepdish bullets with the rears being 45mm offset... perfect fit IMHO
Old Dec 18, 2006 | 09:04 PM
  #47
Hatchman's Avatar
Uh, yeah, I know. I ordered the 42's, they sent the 22's by mistake.
Old Dec 19, 2006 | 01:46 PM
  #48
ronzara's Avatar
Eibach Pro Springs on 2005 V6 Mustang
Got a question for you guys/gals,... Bought a set of Eibach Pro Springs for my 05 V6 Stang, ...my mechanic said that Changing to these springs may require and EXTENSIVE alignment,... camber plates,... and other stuff may be required,... due to the lowering changing the geometry of the stock setup,....
Does this sound correct??
Anybody have to go this far just for a spring change?
Also, I didn't get new bumpstops,.... should I cut the stock ones? Y or N
If so, how much?
Thanks Guys/Gals.!!
RZ
Old Dec 19, 2006 | 07:05 PM
  #49
emperorjordan's Avatar
cut the bumpstops down about an inch.
you may or may not need camber bolts. you dont need camber plates, just camber bolts which are about $40. But there is a chance you will be spot on after the springs. I lowered mine with the BMR springs, which is slightly more aggressive than the pro kit, and it was still within spec, except for toe, which was easily adjusted.
This is assuming the V6 has the same strut design as the GT, which I assume it does, but I dont know.
Old Jan 17, 2007 | 12:35 PM
  #50
555's Avatar
555
Any idea if us eibach sportline guys can do this?
Old Jan 18, 2007 | 06:33 PM
  #51
davids2toys's Avatar
Originally Posted by mikeelia
I like the look of the Bullits, and I decided to keep the front tires and wheels so I got the mustangtuning 18x10 bullit knockoffs for the rear so I could add a wider tire with basically the same diameter and matching Pirelli Pzero nero tires.
So, I have the Steeda Sport springs with adjustable front camber plates with the stock tires and wheels up front and the Pirelli 285/40Z 18s in back.
I haven't decided yet whether I want to go to the 18x9s up front [I hate to add MORE weight or mess with the steering].
Mike E
I went to discount tire and cant find the rear size you mentioned in the p zero nero???
Also, was the color of the wheels exactly the same as the front stock wheels?
Thanks, Dave
Old Jan 19, 2007 | 09:16 PM
  #52
slowjoe24's Avatar
Good Info guys!! Thanks, Joe
Old Apr 15, 2007 | 12:40 PM
  #53
Originally Posted by 06GTwJUICE
My friend has 315/?? 555R's on the rear of his Shelby Cobra kit car and THAT is a truck tire!!!!
Yes, but is this a 15" dia wheel that is so popular on them...that would be a truck tire, but in a 17 or 18 it would not be at all...just wide!
Old Apr 15, 2007 | 02:38 PM
  #54
My next mod is tires and wheels, I am leaning towards the main theme of this thread...I could use some help and advice.
I presently have the stock bullitts and tires with 1" spacers, also have the tri-bar spinner centercaps. I would like to retain them, will they fit on the mustang tuning wheels, so I guess the question would be, will the stock FORD centercap work with these wheels, if they do, then my spinners will work! Also, is the anthracite close to the stock color.
I will probably install 411"s in the rear to make up for the 295's reducing the gear ratio. I would be also cutting 1 coil out of the rear spring which would bring it down 3/4", because the car would be coming up .65" with the tires, so the car would be back at stock height, but with a lot less gap between the tire and fenderwell.
What do you all think? Any ABS or traction control issues with the different tire height from the rear to the front.
Thanks in advance...Dave
Old Jun 15, 2025 | 06:42 AM
  #55
danh's Avatar
Originally Posted by MTAS
You won't regret the 295/45's in the rear. They will however knock your gear ratio down a notch. My 4.10's are now effectively 3.90's, but it's worth the trade off:
Hey, Love your car, I have a 2010 and want to upgrade the wheels and tires. Love the look of your set up. How does it drive with the staggered set up? I would never be on a track.
How does your suspension feel?
Im looking to upgrade there too, want to do it right and not skimp. I dont want harsh. I want better handling however.
Thoughts?
Old Jun 16, 2025 | 12:09 PM
  #56
Bert's Avatar
staggered set-up really doesn't make much difference to the way the car drives -- I doubt any normal human can tell the difference (Randy Pobst might be able to)
the lower the sidewall, the stiffer the suspension will feel -- but if you use 18" wheels and maintain the original 27.2" tire overall diameter, the sidewall will be the same (unless you had 17" wheels before)
if you want balanced handling in corners at the limit, you want a square set-up with the same width tires on the front and back .... but you would probably never approach the limit on the street
for improved handling, you need good tires; don't put too wide a tire on too narrow a wheel; and you might want to consider lowering springs, upgraded struts and shocks, and beefier anti-sway bars
Old Jun 16, 2025 | 02:49 PM
  #57
danh's Avatar
That sounds good to me, thanks for getting back to me. cheers.
Ecostang
Nov 3, 2022 08:50 PM
RRRoamer
Jan 19, 2017 05:27 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
jtolan23
Jul 28, 2015 06:27 AM
