Jlt Install/x2 Tuning
Old Nov 15, 2006 | 08:53 AM
smokenpony's Avatar
I JUST RECEIVED MY JLT/X2 COMBO
NOW I NEED SOME INFO: DO I HAVE TO UNHOOK THE BATTERY BEFORE INSTALLATION? X2 INSTRUCTIONS TALKS ABOUT DISCONNECTING THE FUEL PUMP AND ELECTRIC FAN FUSES. IS THIS NECESSARY?
PLEASE HELP
Old Nov 15, 2006 | 09:03 AM
07ShelbyWanter's Avatar
when i installed my tune off of my x-cal2 from bamachips, no you don't unhook the battery and i didn't disconnect fuel pump or fan fuses and it was fine.
Old Nov 15, 2006 | 09:08 AM
smokenpony's Avatar
Smile
Thanks Jim, Just what I wanted to hear.
Old Nov 15, 2006 | 10:25 AM
smokenpony's Avatar
I was already to go out to install my JLT CAI during lunch at work and low and behold the sensor is attached to the stock intake with torx screws . I have that type of screwdriver at home. . Oh well and I was all excited too. mmmmmmmmm Maybe I can tell my boss I'm sick and leave early *L*
Old Nov 15, 2006 | 10:50 AM
neil07gt's Avatar
Originally Posted by smokenpony
I was already to go out to install my JLT CAI during lunch at work and low and behold the sensor is attached to the stock intake with torx screws . *
Anyone know why torx screws are used instead of philips? torx screws are also used on the hard drive inside my tivo.
Old Nov 15, 2006 | 12:11 PM
sook's Avatar
Just fyi, I think the only reason that they tell you to disconnect the fuel pump ect. is because they don't want the accessories draining the battery while flashing the PCM. Sudden power loss would screw everything up. It would never be a problem leaving that stuff connected unless your battery is almost dead when you flash.
They even used torx screws to secure my sun visors.
Old Nov 15, 2006 | 12:13 PM
ford always uses torx screws.. i bought a complete torx set after I learned that for my Focus hatch back when i was a poorer college kid..
and actually i noticed C&L provides you with 2 Torx bits when you get the Street kit in case you don't have them.. 'nother little bonus
Old Nov 15, 2006 | 12:58 PM
cfr865's Avatar
I went to the hardware store and swithced them to philips head,cheaper then buying a set of torx head tools.
Old Nov 15, 2006 | 01:30 PM
smokenpony's Avatar
Thank god Doug put in two phillips screws with the kit, I'm definitely going to use them.
Old Nov 15, 2006 | 03:55 PM
aircare84's Avatar
Just wait til you go on your first test drive after the CAI & tune...LOL
Scared myself that first run onto the highway,hit 100 by the time I was ready to hit 4th.That was just on the on ramp!
Old Nov 15, 2006 | 04:00 PM
DoctorQ's Avatar
From what I understand, you need to pull the fuel-pump fuse and fan fuse, as ANY type of voltage spike during a reflash can be detrimental to the program status on the PCM. Since the PCM runs checks with other powertrain component modules while key is 'on', guess this minimizes the risk of 'spikes' during a reflash. Just remember to put those two fuses back in after reflash!
Old Nov 15, 2006 | 06:05 PM
Tucker's Avatar
No need to pull the fuse. The SCT book covers many years and all vehicles. The fuse pull is for the older model Mustang.
Just leave all power acc. off.
Jay
Old Nov 15, 2006 | 07:41 PM
aircare84's Avatar
Jlt2
Jay,
Curious as to what difference in the HP gains with your product using the low to high octane? I have a Brenspeed canned 87,89 & 93 tunes. Initally ran the 89 tune, switched to the 93 & noticed an improvement in the low end 'pull'. JLT2+tune is my only performance mod.
Thanks,
Larry
Old Nov 15, 2006 | 08:26 PM
Stoenr's Avatar
Keeps the avg joe from messing with stuff that he shouldn't be, lol.
Just a thought. Also they reduce the risk of stripping
edit -- neil, what are you doing with the hd in the tivo? adding bigger ones?
Old Nov 15, 2006 | 08:59 PM
neil07gt's Avatar
Yes. I replaced the drive in my Directivo with a larger drive. I think it originally had a 40GB drive, i replaced it immediately with a 160GB drive. It will most definitely void your warranty. But you'll get to record over 110 hours of programming. It's not as simple as a direct replacement. You'll need a PC to comlete the job. PM me for details or Google it.
Old Nov 28, 2006 | 07:17 PM
SteelTownStang's Avatar
I didn't pull any fuses and everything works fine
Old Nov 29, 2006 | 06:05 AM
Tucker's Avatar
Originally Posted by aircare84
Jay,
Thanks,
Larry
You would need to ask Brent. Our tunes are different then his.
We see about 20-22 RWHP from 87 and 28-32 from 93.
Jay
Old Nov 30, 2006 | 08:37 PM
aircare84's Avatar
Thanks Jay,
General ballpark was what I wanted to know anyway.
I'm sticking with the 93.
Excellent product, thank you!
Larry
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
RoushRS3
Sep 29, 2015 08:03 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
