Installing the SLP Loudmouth exhaust
Old Feb 2, 2005 | 09:19 PM
rcinco's Avatar
I just ordered a SLP Loudmouth Axle-Back Exhaust, and I called the local Midas shop to find out how much it would cost to install. They said to take off the stock exhaust and install this one would cost $200.
Does this sound right? if not, what should I expect to pay?
BTW - I have no mechanical ability, so doing it myself is completely out of the question.
Old Feb 3, 2005 | 12:39 AM
SixtySix's Avatar
None? Are you sure about that? I'm not world's greatest wrencher either, but this is something you could do with common hand tools. All an axle back is, is nuts, bolts and clamps.
If you must go that route, shop around. I'm thinking that should run you more like a hundred bucks. Can't see it taking more than hour. I doubt their shop labor rate is $200 hourly.
Old Feb 3, 2005 | 04:18 AM
stefano's Avatar
hi rcinco,
SLP is for stainlessworks exhaust,right?
could u please post a sound clip when installed?
thanx!
Old Feb 3, 2005 | 04:36 AM
Mustang69-05's Avatar
Even with NO skills at all it shouldn't take you more than an hour to put these on. Each clamp has two bolts, slide it off. Reverse back on. I would definatly shop around if you refuse to get your hands dirty. I wouldn't think more than $50.
Old Feb 3, 2005 | 06:01 AM
snkbtn99's Avatar
If you pay the $200 you're nuts ..... Like others have said, the biggest part of this chang eout is getting the rear end up in the air. If you have a good set of stands or Rhino ramps and you can undo a few bolts, you are done ....
Save yourself the $200. Even if you did have them do it, it should be more than $50. They could do this in 10 minutes ...
Old Feb 3, 2005 | 09:32 AM
XG14's Avatar
$50. to $100.
sounds right to me.
Old Feb 3, 2005 | 09:34 AM
Altoid's Avatar
Jackass
This should really be in the S197 GT Tech & Performance forum. I think my local place charges around 70 an hour.
Old Feb 3, 2005 | 10:19 AM
rcinco's Avatar
Originally posted by stefano@February 3, 2005, 3:21 AM
hi rcinco,
thanx!
I'll definitely post a sound file after installation. Stay tuned.
Old Feb 3, 2005 | 10:20 AM
rcinco's Avatar
If it's this easy, then I'm doing it myself.
Keep in mind, it took me over 20 minutes to replace the gear shift **** on the car, so you may want to change your time estimate.
Old Feb 3, 2005 | 11:05 AM
Galaxie's Avatar
I Have Admin Envy
I would say that this install is dirt-simple. I am sure you can do it yourself in about an hour.
If you would rather pay someone, the most I would pay is $50
Old Feb 3, 2005 | 11:12 AM
rcinco's Avatar
What equipment do I need? I don't have anything beyond the basics (screwdrivers, pliers, etc.).
Thanks in advance.
Old Feb 3, 2005 | 11:27 AM
Just a socket set to take the nuts off the clamps. Everything else just slides in and out. You just have to be able to get under the rear end and give yourself some room, it will make your life easier. Trust me you can do this....
Old Feb 3, 2005 | 11:58 AM
ZRX4ME's Avatar
just from looking under my car ,I would think you don't even need to jack the car up at all.
Old Feb 3, 2005 | 04:23 PM
ZwerRacing's Avatar
YOU CAN DO IT!!! and if you can't $50-100 max.
Old Feb 3, 2005 | 08:46 PM
subzero05's Avatar
YOU can easily do this!..Easiest exhaust change I have ever seen probably!.If it takes you over an hour I would be surprised!..Remove clamps in the back, pull out muffler hangers and install new kit in reverse order!...DONE..Oh , SLP stands for Street Legal Performance
Old Feb 3, 2005 | 08:52 PM
rcinco's Avatar
Thanks, everyone. I will give it a try and let everyone know how it goes.
Old Feb 3, 2005 | 10:02 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Hey man, found a site w/ install pics for the system on an '04. Maybe it'll help you. Soundclips too. Hope it's OK to link there.Link
Old Feb 3, 2005 | 11:20 PM
GtStallion51's Avatar
The system for the 05 should be a lot louder since it really is just a muffler delete, unlike the version for the 04 which had some form of "muffler" ..... I've been thinking of going with slp too, so a sound clip is needed....
Old Feb 4, 2005 | 10:23 AM
tech's Avatar
I installed this system on mine and it took about an hour and a half. The problem was that once it's unclamped you have to slide the stock mufflers forward toward the front of the car instead of toward the rear. So, you have a lot of obstruction. I ended up taking off the hangers closest to the front of the car for ease of removing the stock setup. The proves to be a little challanging because it's tight quarters.
And, yes you absolutely need to jack up the car. I tried it without and was cussing up a storm.
Old Apr 8, 2005 | 11:05 AM
walkman71's Avatar
Check out your local muffler shop, i just paid $150 for them to put straight pipes on my 05 which is what the loud mouth is right? It sounds loud as heck and very deep.
