Installed a Coast driveshaft tonight
Old Oct 14, 2008 | 07:16 PM
GRAYPNY's Avatar
Thumbs up Installed a Coast driveshaft tonight
As some of you may or may not know I was going to sell my car a few months ago. I sold the Spydershaft to a member here and also sold afew other parts that I have replaced.
I always missed the 1 piece driveshaft and since I had a Spydershaft on it before (zero issues) I decided maybe I would give the Coast shaft a try. I found a used one for $375 shipped and the owner of a local hot rod shop and I installed the Coast tonight. Total time of install was 1 hour 5 minutes. We did it on a rack so we had the move the car back and forth a few times to rotate the rearend.
Took it out for a spin and I immediately remembered how fast the rpm's spool up with the aluminum driveshaft. Got it up to 100 and no vibrations at all.
The Spydershaft was great but not having remove the pinion flange and torguing that pinion nut to 150 ft lbs wasn't missed one bit.
Anyone who is on the fence about a 1 piece aluminum driveshaft can take it from me, it's a great mod!
Old Oct 14, 2008 | 07:36 PM
John H's Avatar
I'm new to this topic in general. Is that the main benefit of an aluminum driveshaft, faster reaching higher RPMs? Well, that and the weight? Is there any other benefit that a stock or slightly modded GT would get out of it?
Old Oct 14, 2008 | 07:41 PM
shatter's Avatar
Good news is that Rich will take it off and sell it again in a couple of weeks and you can pick it up on the cheap. Then he'll buy another one a few weeks later... rinse, wash and repeat.
Old Oct 14, 2008 | 07:45 PM
SONICBOOST's Avatar
Nice! I will get one if I go for 500rwhp...
Old Oct 14, 2008 | 09:28 PM
GRAYPNY's Avatar
You won't have the clunking noise, less rotating mass, 20 lbs vs 40 lbs so it spins the rpm's much faster. I don't have a highly modified engine but there are claims that it can give you .2 better e.t. if you're a drag racer.
GRAYPNY's Avatar
What a ball buster!
Old Oct 14, 2008 | 09:32 PM
JonCo's Avatar
I'd love to get my hands on a nice deal for a 1 piece.
Old Oct 14, 2008 | 09:33 PM
+1 I need a good mod to do this winter.
Old Oct 14, 2008 | 09:52 PM
an aluminum 1 pc driveshaft is one of the best mods you can do
Old Oct 15, 2008 | 07:33 AM
+1 for the Coast DS.
Rich, did you relocate the e-brake cable bracket and pound down the hump in the center tunnel?
Old Oct 15, 2008 | 11:38 AM
MaverickMLFD371's Avatar
i get mine installed on Saturday @ Tillman Speed
Old Oct 15, 2008 | 06:11 PM
GRAYPNY's Avatar
I pounded down the tunnel hump and didn't see any reason to mess with the e-brake cable. I never had an issue with the 4 inch Spydershaft so I doubt that it was even necessary to mess with the tunnel hump.
Tunnel Hump!
Old Oct 15, 2008 | 06:14 PM
Cali HP addict's Avatar
Happy for you bro!
Old Oct 15, 2008 | 06:16 PM
GRAYPNY's Avatar
Originally Posted by Cali HP addict
Happy for you bro!
Yeah and you didn't have to bust your n**s on this one either. Got to get together soon.
Old Oct 15, 2008 | 07:41 PM
CalStang'07's Avatar
Cool Clunk really gone?
Rich: Does this 1-piece aluminum drive shaft install really eliminate that horrid clunk sound in the drive train when you shift from 1st to reverse and release the clutch, when the Stang is not hardly moving? That is one thing that I have really hated about our other wise great CalStang!!! "RC"
Old Oct 15, 2008 | 08:22 PM
GRAYPNY's Avatar
eliminate no, reduce yes.
Old Oct 18, 2008 | 05:10 PM
well I got my coast installed today by CR @ tillman speed and all i can say is WOW!!!!!!!!!!!!! the clunking has dissapeared!! the car revs up soooo much faster and the driveline is soo much smoother!! Coast D/S is def the one to get!! hands down. thanks once again to CR @ Tillman Speed!
Old Oct 18, 2008 | 05:50 PM
GRAYPNY's Avatar
Good deal!
Old Oct 20, 2008 | 03:16 PM
buffguy's Avatar
How much does the stock driveshaft weight.
Old Oct 21, 2008 | 05:16 AM
40 lbs!
