incorrect rear spring position cause small noises?
Old Jun 28, 2007 | 09:57 AM
YaoNYC's Avatar
hi there..
can this be possible? i only hear noises as very low speeds over small and big bumps?
Old Jun 28, 2007 | 08:02 PM
MooStang05gt's Avatar
Did you remove or cut down the bump stops on the top of the axle tube, just to the out side of the springs. See the attached photo.
Bobby M.
Attached Thumbnails incorrect rear spring position cause small noises?-p1040315.jpg
Old Jun 28, 2007 | 08:42 PM
YaoNYC's Avatar
Bobby M.
im not sure..i have to ask my shop guy...
if the bump stop is NOT removed what does that do?
thanks very much bobby!
Old Jun 28, 2007 | 08:49 PM
tom281's Avatar
To answer your question, yes it can cause noises. Regarding the bump stop, I didn't cut mine as there are no directions from Steeda to do this, and I have no noises.
It seems to me that the bump stop is there to keep the suspension from bottoming out- cutting it would allow the rearend to bottom out more quickly, unless I'm not understanding what the purpose of the bump stop really is.
Old Jun 28, 2007 | 08:55 PM
max2000jp's Avatar
Tom it's just the opposite. Cutting the bump stops creates more clearance between the foam "stop" and the chassis. You should cut your bumpstops off. It's a 5 minute job with a hack-saw.
Old Jun 28, 2007 | 08:56 PM
kevinb120's Avatar
No issues with bottoming out here either. Mine makes a few noises on speed bumps. Probably the stock LCA bushings creaking a touch as they are a little out of their stock range without relocation brackets. The slight creaking front and rear on speed bumps went away for the most part after everything settled. I have never come remotely close to bottoming out.
I would think that if you bottomed out with shorter stops, the stock panhard bar could conceivably snap.
Old Jun 29, 2007 | 01:07 AM
RedDragon777's Avatar
or just bend the whole rear end to the driver side which would su(k for all your control arms
Old Jun 29, 2007 | 04:43 PM
07 HOSS Mustang's Avatar
with the Eibach Pro springs I only had an inch left between the bumpstops and the frame. You need to cut off at least one inch of the bumpstop with a small hacksaw to get more travel before bottoming out.It is soft rubber/foam and easy to cut.
Old Jun 29, 2007 | 05:56 PM
tom281's Avatar
Hey thanks man, I stand corrected! And some apologies to MooStang05gt: didn't mean to doubt you.
Old Jun 29, 2007 | 07:13 PM
Not a big deal with me...
Bobby M
Old Jun 29, 2007 | 09:44 PM
YaoNYC's Avatar
thanks for the feedback guys.
does NOT cutting bump stop cause small knocking noises when i go over bumps at slow speed? say...15-30 mph??
Old Jun 29, 2007 | 10:35 PM
Just for grins.. .. Listen real close to see if it is your trunk latch hitting against the catch bar... that can make knocking sounds over bumps. If you don't have someone to assist you, drop the rear seat backs to open up the trunk area.
Bobby M.
Old Jun 29, 2007 | 11:30 PM
YaoNYC's Avatar
Bobby M.
hi bobby M.
great idea! i'll do that and thanks very much!
SMBJoshy
Aug 24, 2015 10:55 AM
SpeedyJoe
18
Aug 23, 2015 02:42 PM
RocStar69
Aug 21, 2015 07:33 AM
Mug-stang
Jul 31, 2015 10:25 PM
