I need imediate help!
On my 2000 I took the top hose elbo off, took the thermostat out and filled the engine block. I then put the thermostat in, bolted the elbo down, filled the radiator and cranked it up.
its a little bit different on these cars. The t-stat isnt on the block.
C'mon there has to be someone that knows these cars better than I do that has done the water pump!
<div class='quotetop'>QUOTE(dustindu4 @ February 4, 2006, 6:29 PM) Quoted post</div><div class='quotemain'>
you have email
[/b][/quote]
The email that you sent me has a virus.
you have email
[/b][/quote]
<div class='quotetop'>QUOTE(dustindu4 @ February 4, 2006, 6:42 PM) Quoted post</div><div class='quotemain'>
WTF
did it say which?
[/b][/quote]
NO it didnt.
Name of File SECTION303-03-EngineCooling.zip
Virus Scan Result Unknown virus scanner failure Virus Found
Note: There is no cure available for the virus on the file SECTION303-03-EngineCooling.zip
It is not possible to download files from Hotmail that contain incurable viruses. Contact the originator of the file, inform them that the file contains a virus, and ask them to send a virus-free version of the file
WTF
did it say which?
[/b][/quote]
NO it didnt.
darn Dustin, don't send me any emails [img]style_emoticons/<#EMO_DIR#>/shakehead.gif[/img]
Norton 2006 says it's clean, but here
<div class='quotetop'>QUOTE(Blazing Saddles @ February 4, 2006, 9:50 PM) Quoted post</div><div class='quotemain'>
Dustin you need more protection than this.
[/b][/quote]
funny guy
[/b][/quote]
funny guy
Guest
Posts: n/a
Location: New Carlisle, Ohio (20 miles north of Dayton)
<div class='quotetop'>QUOTE(300HPGT @ February 4, 2006, 8:14 PM) Quoted post</div><div class='quotemain'>
I have just put on my Mezere water pump but I need to know how to prime the system.
[/b][/quote]
When I installed mine I just filled the radiator full and turned on the ignition to run the Miezere pump. It burped itself without the engine running. Then I started the engine, turned on the heater controls to hot and in only took a few extra ounces more. Have you tried to just run the Miezere pump only yet??
Scott
[/b][/quote]
Scott
<div class='quotetop'>QUOTE(70MACH1OWNER @ February 5, 2006, 4:01 AM) Quoted post</div><div class='quotemain'>
Scott
[/b][/quote]
Same thing here. I let the pump do it. But, I didn't completely drain the system, either.
Scott
[/b][/quote]
Comox
2007-2009 Mustang GT/CS
13
11/29/06 12:03 PM
