I can't win.... Any ideas?
After I solve one noise another always seems to pop up. I just installed rear lower control arm relocation brackets and now have a popping noise in what I believe is the front end but could be mid point somewhere as well. It sounds like something binding then "popping" into place. It does it while turning over bumps and pretty sure it did it a couple times while jacking it up. I have Eibach prokit springs with tokico hp struts and UMI relocation brackets. I really can't see how the brackets could be related and thinking it may just be a coincidence that it happened after I installed them. I am leaning to new camber plates but just wondering if any of you have other ideas? For example would camber plates pop while jacking it up? And when jacking it sounded mid car yet when driving it feels like front.
Thanks!
Thanks!
lol
if only this thread would have been up a long time ago..i would have save alot of money...but i got better than stock parts so im happy anywho...but i had the same issue, after i lowered, then i bought new struts...still didn't fix...then new caster camber plates...still didn't fix..finally i figured it out about the loose stuff about 800 dollars later hahah
From what I can tell you can't really get the thing as tight as Ford wants. I mean who uses a 8mm fastener on a 80ft/lb connection? I got mine as tight as I could and used blue loctite. Also marked the thing so if it changes I can see them quickly.
