How to get a stock 4.6 to 400hp naturally?
Old 1/7/11, 07:30 PM
Corstang427's Avatar
Ive had a 06 GT for almost a year and it has only 3500k on the odometer. I was wondering if anyone knows how to get 400hp without using forced induction, engine swap, and keeping the mods price under 4k? Tips would be helpful, thanks!
Old 1/7/11, 07:55 PM
jaguarking11's Avatar
Laughing gas.....
Old 1/8/11, 08:32 PM
ipchay61's Avatar
Haven't heard from anyone who has installed this but it sounds interesting.
http://www.fordracingpartsdirect.com...m-fr4-s197.htm
Old 1/8/11, 09:31 PM
mcate's Avatar
If it's hp at the flywheel, then CAI, tune, cams, long tube headers, offroad mid pipes, & U/D pulleys should put you in the ballpark. I've been told around 380 or so.
Old 1/13/11, 12:00 AM
Imatk's Avatar
You'll spend a lot more money trying to get to 400hp with bolt-ons than you would if you just slapped a blower on the car.
Old 1/13/11, 12:12 AM
5pointoh's Avatar
That list doesnt too shabby
Old 1/13/11, 03:59 PM
PIKE2244's Avatar
Ok so lets put it this way until recently I was N/A w/ just about every bolt on you could do: Cams / Heads / Intake / Custom Tune / TB / UDP / FRPP Intake Manifold / LT's Hi Flo Cats & Magnapaks and I was right around 390rwhp give or take... Hope this helps!!!
I have to say though after spun bearing now I am going w/ a 5.0 stroker 298ci from Livernois / Heads & Cams / 2.3 whipple at 16 - 17 psi / new clutch / and much more... Should be pushing a little over 600rwhp; maybe something around 610 -615rwhp... VERY EXCITED!!!! Should be done in about 2 wks at most... Sorry don't mean to hijack the thread.
Old 1/13/11, 04:41 PM
Everett's Avatar
That is gonna cost alot of money
Old 1/13/11, 06:42 PM
ipchay61's Avatar
What kind of times were you running when NA?
Old 1/13/11, 07:36 PM
goldhillstang's Avatar
I think MM&FF put this on a dyno and got around 423 hp at the crank. It was in a issue a few months back. Might have been 432 hp. Can't seem to find the mag issue right now.
Old 1/13/11, 08:55 PM
bob
bob's Avatar
The guys at Livernois tested that combo for MM&FF and it was right around 430hp
I wonder if that 1.53 hp/ci would hold up under a 5.4? If so your talking 500hp +/-, its to bad Ford never produced an aluminum 5.4 block designed to work with the 3v heads. If the hp/ci thing doesn't hold up then adding 49 cubes would put it into the 470hp range.
Old 1/13/11, 10:19 PM
Hawaii 5.0's Avatar
Free up your exhaust with longtubes and x-pipes, u/d pulleys, intake, throttle body & plenum, gears and cams. Should be under 4k and you should be right around 400hp.
Old 1/13/11, 11:28 PM
5pointoh's Avatar
Gears wont add to the HP number......but will surely make your car go vroom vroom much more quickly. I am thinking of getting the 410 gears that everyone is raving about.
Old 1/13/11, 11:43 PM
Hawaii 5.0's Avatar
I guess i meant to feel your power add gears. But yea 3.73's are workin great for me so far
Old 1/14/11, 05:39 AM
mcate's Avatar
I've got 4.10's & love them. Driveability around town is much improved, highway rpm isn't bad, & gas mileage (not that I care) doesn't suffer.
Old 1/14/11, 01:15 PM
PIKE2244's Avatar
So I was running around 12.6's consistently but I feel there was more in it with a better driver... And yes the setup I had N/A was a little pricey (But compared to what I am paying now it is a drop in the bucket. So it is all in ones perspective). I mean I never intended to spend this much money but I wanted to do it right and one thing lead to another and here I am....
Old 1/14/11, 01:32 PM
fdjizm's Avatar
I'm in the 12.8's (mph for 12.7's) with less than $1,000 I can't complain
Old 1/14/11, 02:08 PM
PIKE2244's Avatar
Thats why I said there was more in my car; more so driver error.... hahaha. I believe my car could go 12.4 w/ gears and better w/ DR's but I will never know. Now all I'm thinking about is mid 11's...
Old 1/14/11, 07:05 PM
jwgroovin's Avatar
Mid 11s very doable!
Old 1/14/11, 07:08 PM
fdjizm's Avatar
What cams do you have? I think that will be my next mod after long tubes.
Quick Reply: How to get a stock 4.6 to 400hp naturally?
