High-Temp Paint
Old Apr 4, 2007 | 10:52 PM
Jon_Purdy's Avatar
High-Temp Paint
I'm in need of high-temp black paint as I've gotta paint my Flowmaster A/T's. Any suggestions?
Cheers,
Jon
Old Apr 5, 2007 | 04:25 AM
LimeGT's Avatar
Any high temp paint from any auto parts store should work. The mufflers don't get very hot anyway, not like headers or an exhaust pipe closer to the engine. Different brands may vary as far as gloss. If you want them glossy, use engine enamel. It should withstand the heat of the mufflers.
I have the Flowmaster A/Ts and they came painted black. Why do you need to paint yours? Just curious.
Old Apr 5, 2007 | 07:58 AM
MTAS's Avatar
Ditto what Phil said. I used a hi-temp flat black to paint my Hooker AeroChambers. They're polished stainless steel from the factory, a little too much for me, at least for the mufflers. I used a hi-temp primer first, then several thin coats of the hi-temp black and it's held up very well. You will smell the paint curing for a few days though.
Old Apr 5, 2007 | 12:09 PM
metroplex's Avatar
I've used aerosol and brush-on Rustoleum High-Temp Paint in the past with negative results. After a few years the paint tends to peel off or flake off.
The brush-on Rustoleum Stops Rust! paint does seem to adhere to stainless steel very well.
Old Apr 5, 2007 | 09:45 PM
Jon_Purdy's Avatar
The black has started to fade a bit. Driving the car throughout the winter might have something to do with that.
Old Apr 6, 2007 | 04:09 AM
LimeGT's Avatar
Mine look pretty faded too, now that you mention it. Very dull, grey looking almost. Guess I have something else to add to the list of 'things to do'.
Old Apr 6, 2007 | 09:13 PM
06GTblackvert's Avatar
I just painted my mufflers with black barbecue paint... I hated seeing the mufflers hanging from the rear of the car. Now my chrome tips really stand out.
Old Apr 7, 2007 | 06:42 AM
SteelTownStang's Avatar
I just used regular flat back paint to touch-up some scratched and it worked fine. If you're painting a larger area, any high-temp paint will work. As mentioned earier, the mufflers don't get that hot...
May 3, 2026 05:42 AM
robjh22
Dec 14, 2015 08:41 AM
Cobiecane
Oct 23, 2015 08:44 AM
GLOCKer
Sep 28, 2015 05:20 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
