High Flow Cats
Old Dec 25, 2007 | 10:00 AM
colbymh's Avatar
High Flow Cats
Anyone using them, have them, or know of good ones to purchase?
Also, with them being less restrictive, will there be hp gains? louder/throatier??
Thanks for any input.
Old Dec 25, 2007 | 10:25 AM
bob's Avatar
bob
Hi-flow cats, probably wont do much in terms of HP if the current system is capable of supporting 300+ with no restriction, becaue of their hi-flow nature, the cats will probably allow more niose to pass (my SLP cats were noticably louder when you hit the gas, otherwise they werent loud at cruise or idle).
Hi-flow cats at the stock stage of the game are like mufflers, they really dont add much in terms of power, but are really more about getting the sound you like and being emissions compliant.
Old Dec 25, 2007 | 11:01 AM
turbo05gt's Avatar
What ever you do stay away from dynatech cats!!
Old Dec 25, 2007 | 11:34 AM
colbymh's Avatar
Are they even worth buying then? I want some added sound, but I plan on putting borla stingers on anyway. If there isnt any hp gains from them, then I will probably scratch them off my list.
Old Dec 25, 2007 | 03:16 PM
metroplex's Avatar
I have high flow cats. Ford bolted them onto my GT at the factory.
Old Dec 25, 2007 | 03:39 PM
SONICBOOST's Avatar
They will open up the exhaust. I am looking for some highflow cats to go with my prochamber to make it a little louder
Old Dec 25, 2007 | 06:55 PM
smileyjoe's Avatar
I was just wondering if anyone has tried to have the cat's taken off their factory exhaust ? Wouldn't that be just like having an off road h-pipe ? I think the factory exhaust is 2 1/2 inch.
Old Dec 26, 2007 | 06:57 AM
SC67Stang's Avatar
I have High flows on the Magnaflow X-pipe I added.
Don't think the cats gave me any ponies but it did give me a louder sound at WOT. Did gain 5 ponies but more than likely from the X.
Sounds not much different at idle from before.
Old Dec 26, 2007 | 03:25 PM
Pwny's Avatar
How bad are dynatech cats? I saw a thread about one failing but how many people are having problems?
Old Dec 26, 2007 | 05:42 PM
gloryboy's Avatar
I believe it was Don W that had a dynatec cat fail and plug the exhaust pipe causing his engine to blow ......I had 2 different jba cats fail on me about 2 months apart under normal driving. Stay away from cats with a ceramic substrate (too delicate)......there are race cats that have a spun steel substrate that is much sturdier. I have been running a set for about 8 months with no probs.........got mine from a local muffler shop about 180 each, i'm sure you could do better on the price though.............as for gains, i have heard they are minimal in going to off road set up, so i doubt high flow cats get you much at all........
Old Dec 26, 2007 | 06:13 PM
Pwny's Avatar
How do you know when a cat fails? No exhaust coming out?
Old Dec 26, 2007 | 07:49 PM
gloryboy's Avatar
When mine went, it sounded like a couple of large bolts bouncing around in a metal can under the car. The ceramic substrate had fractured and pieces of it were rattling around inside the cat every time i stepped on the gas or hit a bump...........luckily the pieces never completely obstructed the exhaust flow.
Old Dec 26, 2007 | 08:30 PM
TASSY5's Avatar
Here is a good question for you Guroos.
I am putting a Whipple HO. SC on my car in the next week.
I currently have a Spydershaft 1 pc drive shaft and STOCK H PIPE with PYPES/Cervini's mid mufflers with side exits.
I had a Pypes ORH pipe but the side exit made it EXTREEMLY Too lous and Glass pack sounding so I took it off and put the Stock H Catted pipe back on. That did give me the sound I want for cruising but wish it were louder at WOT. (I guess i have to give alittle to get a little).
With the stock Manifolds and Catted H pipe will I be hurting the car as for performance not going with a Hi Flo Cat system or LT header system???
Old Dec 26, 2007 | 08:54 PM
d_gusler's Avatar
IMO the factory cats are already top notch. Its a waste of money installing hi-flow cats. I heard a couple sets installed on S197s, and they all sound like the factory units IMO.
Old Dec 26, 2007 | 09:26 PM
TASSY5's Avatar
what about LT's over the Stockers with FI ?
Old Dec 26, 2007 | 11:13 PM
Pwny's Avatar
Geeze. Glad it didn't end bad for you.
Old Dec 27, 2007 | 01:35 AM
zaghloul's Avatar
I think thats true. I can't think of any other difference.
Old Dec 27, 2007 | 08:04 AM
gloryboy's Avatar
With forced induction, LT's should be good for about 20 or so rwhp.......
Old Dec 27, 2007 | 10:59 AM
Kluski's Avatar
I installed a Bassani X-Pipe and kept the stock mufflers. At first I used the straight legs without cats. But the smell got to me after a while and seeped into the house from the garage. I put the highflow cats in. There is still a definete louder sound with the high flows, bassani x-pipe and stock mufflers.
Here is a clip with some different sound clips I made when changing my exhaust:
http://c5photog.ipower.com/MyCar/Bas...SoundMovie.wmv
Old Dec 28, 2007 | 04:41 PM
RFLgtcs's Avatar
so basically if i were to get LT headers and a hi flo catted mid pipe, the off road setup wouldn't be much of a different when it comes to airflow, hp gains, and loudness?
i was thinking of the american racing headers and hi flo cattted midpipe, does anyone know what those cats are made out of and if those are safe?
