Help with Tire size for 18x10 & 18x9
Old Aug 10, 2005 | 10:47 AM
Weedo's Avatar
So I've decided on a set of rims in 18x10 (rear) and 18x9 (front). What tire size are you finding will fit best on this rim on our car?
Old Aug 10, 2005 | 10:56 AM
adrenalin's Avatar
why 18x9 in the front? If you go 18x10 in the rear, put 285/40's on it. They will be 27" in diameter so your speedo won't change. I put 18x8 on the front with 255/45's. They were also 27" in diameter. Stock tires are 27.2" in diameter.
Edit: Perhaps this should be moved to Exterior mods. It really has nothing to do with performance for the GT since these rims will also fit on a V6. There are a lot of tire threads under the exterior mods that you may want to do a search on.
Old Aug 10, 2005 | 11:43 AM
Weedo's Avatar
I have a choice of 18x10 or 18x9 in the front. I don't see the point of 18x10 all around so I might as well save the weight/cost of the larger rim/tire from the front.
This can be moved if you would like, but I see this as a necessary "performance increase" for a GT with more power than stock, like, oh, say a supercharger?
Old Aug 10, 2005 | 03:11 PM
Stang281's Avatar
Check sig. for the setup i'm going with.
Old Aug 10, 2005 | 07:12 PM
Moondog's Avatar
check out the Roush - 18 x 10's on each corner with 275 X 40/ 18"s. looks goooooood! Also - check out tire rack's web site - good data wrt manufacture's recommended rim width by each tire size.
Old Aug 10, 2005 | 10:39 PM
05STG1's Avatar
I'll have to agree with that
[attachmentid=30251]
No reason not to put 18x10 on all 4 corners w/ the 275/40's. U could rotate...same side that is w/ the comp tires.
I love it, handles great.
SS-
14BlackGT
Aug 26, 2015 12:33 PM
JonathonK
Jul 27, 2015 07:35 PM
