Help Centering Mufflers
Installed GTAs over the weekend and the passengers side is not quite centered in the middle of the circular bumpber cut out. Are the four hanger bolts what I need to re-loosen, or do I need to re-loosent the clamp bolt or something else closer to the motor?
thanks!
mitch
thanks!
mitch
Loosen the two bolts on the clamp that holds the over axle pipe to the mid pipe. It's very easy to do and will allow you to center and adjust the amount that the tips hang out of the bumper. It's easier if you have two people there but I did it by myself with no problem and I'm no mechanic, lol.
