Header gasket
Old May 12, 2010 | 10:02 PM
SONICBOOST's Avatar
Header gasket
I ordered Mac longtubes and forgot about the header gasket. I should order new ones right? The only gaskets I see on brenspeeds site are for kooks? Thanks
Old May 12, 2010 | 10:13 PM
MadMoose's Avatar
my kooks headers came with some gaskets idk if mac is the same way
Old May 12, 2010 | 10:15 PM
Exhaust leaks at the manifold can warp valves because they suck in cold air.
Git 'er dun!
Old May 12, 2010 | 10:31 PM
SONICBOOST's Avatar
Should i get gaskets from a local Ford?
Old May 12, 2010 | 10:42 PM
They might work but I don't know if manifold gaskets mate perfectly with the headers. Do they fit in a recess in the head? Or is the head a flush mount design?
Its been years but as I remember they are a sort of metal material that compress as you torque the header down.
Old May 12, 2010 | 11:02 PM
SONICBOOST's Avatar
I got them today and no gaskets. I'm sure if i paid $1,400 for a complete setup I would have gotten gaskets I heard you can reuse the factory gaskets but I will most likely pick up some stock steel ones from a local Ford dealer. Thanks
Old May 12, 2010 | 11:03 PM
SONICBOOST's Avatar
I believe they are flush..
Old May 12, 2010 | 11:07 PM
Maybe it was a mis-pick - give them a call. I would think with flush mount you have a bit more flexability. As long as all the header mounting surfaces are completely covered you should be fine and of course the manifold studs are going to position everything correctly.
Definitely get new ones.
Old May 13, 2010 | 12:33 AM
ieatv8's Avatar
Re-use your factory gaskets.
Old May 13, 2010 | 12:46 AM
They've already been compressed to the manifold configuration - not the header. Why cheap out and risk warped valves?
Old May 13, 2010 | 12:50 AM
2kanchoo's Avatar
I just picked up some 2 piece oem ones from the dealership. Worked fine for me.
Old May 13, 2010 | 01:51 AM
DynamicmustangGT's Avatar
The factory ones suck they come two pieces per side. My borla headers came with nice gaskets that seal well. Get a set of them from summit/kegs etc...
Old May 13, 2010 | 09:51 AM
Green96GT's Avatar
get the percy gaskets, they are the best
Old May 13, 2010 | 10:09 PM
SONICBOOST's Avatar
I picked up some stockers from a local Ford. Install this weekend
Old May 16, 2010 | 03:58 PM
70MACH1OWNER's Avatar
How is that install coming Adaaam?
Old May 16, 2010 | 07:02 PM
SONICBOOST's Avatar
Headers are done just have to wait till tommorow to take it to a shop to have the down pipe welded to the midpipe cause right now its an open header monster! Ill make a thread and post vids!
Old May 26, 2010 | 02:21 PM
SONICBOOST's Avatar
Everything is all done up and welded and man o man does this exhaust bring the biggest smile to my face Doing the pulleys tommorow because I got called into work last week but should get some vids this weekend and post them up
Old May 27, 2010 | 03:28 PM
Hurry up Adaaam...I ain't going to live forever!
Old Jun 1, 2010 | 11:26 AM
SONICBOOST's Avatar
I am slackn but it was memorial weekend You gotta remember i'm not an old guy like some of you, I like to get a little loose on the holidays JK buddy i'm gonna get some vids soon
Old Jun 2, 2010 | 06:33 PM
tom281's Avatar
My best installs came with assists from some kind of alcohol.....
