Good Pictures of Eibach Pro Kit Install
Old Jan 12, 2006 | 01:43 PM
MI2QWK4U's Avatar
Some of you asked what the before and after difference was with the Eibach Pro Kit on the 06 Mustang. The before pics were taken at the shop by Lidio and he only just sent them to me today. The drop was just over 1 1/2 inches all the way around. That wide open gap above the wheel kills the look. I am pleased that the wheel much better fits the wheelwell now.
BEFORE-FRONT
AFTER-FRONT
BEFORE-REAR
AFTER-REAR
BEFORE-PROFILE
AFTER-PROFILE
Old Jan 12, 2006 | 02:08 PM
mhk's Avatar
mhk
Good pics, nice rims!
Old Jan 12, 2006 | 02:23 PM
Murphy77's Avatar
nice pics performance white is looking better than i thought
Old Jan 12, 2006 | 02:39 PM
Rondosa's Avatar
Meet Krissy, Our Star Racer
believe it brotha! performance white is hot!
my eibach kit picture:
Old Jan 12, 2006 | 02:44 PM
Did (or are) you address the alignment camber issue? And what of the rear axle centering issue?
Old Jan 12, 2006 | 03:13 PM
karrnutt's Avatar
How has the installation affected the comfort of the ride on your great looking white Gt?
Old Jan 12, 2006 | 03:31 PM
Boltzman's Avatar
Also do you notice bottoming out at all ?
Old Jan 12, 2006 | 03:40 PM
AGBULLIT's Avatar
Great pics!
Old Jan 12, 2006 | 05:18 PM
Patience's Avatar
i knew that was lidio's shop before even reading it---what did he charge you for the install? thanks
Old Jan 12, 2006 | 07:32 PM
MI2QWK4U's Avatar
I am very happy with the results. I will have the allignment checked. As for the ride, It doesnt seem to be affected much at all, its a little bit stiffer, but the ride quality is still outstanding. When I put this kit on my 04 Mach 1 it really made the ride a lot stiffer, but not on the 06. I have not had any issues with bottoming out at all either.
Old Jan 13, 2006 | 08:34 AM
rony1976's Avatar
I dropped my PW a couple of weeks ago, only problem I had was on a slope, at the top, scraped the bottom a bit, but nothing bad.
What about painting the calipers red? It made the world of a difference when I did mine...
Old Jan 13, 2006 | 02:02 PM
don_w's Avatar
The pics need to be bigger, I can barely see them.
Old Jan 13, 2006 | 03:25 PM
SurfnSoCal's Avatar
still ALOT of wheel well gap. :-\
but I like the color and wheel combo alot.
Old Jan 14, 2006 | 12:06 AM
05-1947's Avatar
Looks good!
Old Jan 14, 2006 | 02:15 PM
Rondosa's Avatar
seriously? the pics at the top are after it was just done I'm assuming, so you have to give it some time and they'll settle down lower.
you don't want it gangtsa slammed, else the gap between the tire and the fender becomes uneven and smaller at the top of the rim. :notnice: i'm biased, but i think the gap and height are perfect!
in terms of alignment, i elected to install the steeda billet camber plates at the same time to avoid any problems - the shop had no problems aligning the car. through i can't say that if i didn't have them, that i'd have had a problem.
i've had no clearance problems with the car, and havne't scrapped anywhere. ride confort is fine, but firmer then stock, though not harsh. personally i would recommend that anyone installing aftermarket springs should also do shocks at the same time. the tokico d-specs are really nice, though pricey. hopefully more companys will come out with 05-06 mustang shocks soon.
kristina
Old Jan 16, 2006 | 01:38 PM
mikeelia's Avatar
I sure do with my car, and I have the Steeda Sports which don't lower the front quite that much! There are a couple of driveways I have CRAWL over to avoid scraping.
Maybe here in SoCal where the storm drainage is mostly handled by driveway slopes and concrete surface "dips" it is just worse.
Mike E
Old Jan 16, 2006 | 07:26 PM
islandmustang's Avatar
just add some beefier tires to get rid of the remaining gap... that would look more retrooooo....
ssjbuu
Aug 28, 2015 08:55 AM
ToddMcF2002
'10-14 Exterior Modifications
17
Aug 3, 2015 07:42 PM
killaz05
Jul 24, 2015 08:49 AM
aphaynes
Rocket City Mustang Club
Jul 9, 2015 09:25 AM
