gear whine?
Old Nov 12, 2007 | 09:21 PM
fla.boy's Avatar
Exclamation gear whine?
hi guys
quick question! are 4.10 supposed to whine? i have a whine at variouse speeds. the shop that did the install said it was normal for 4.10 to whine. is this true? thanks! p.s. i love the gears ! really woke up the car!
Old Nov 12, 2007 | 09:34 PM
281GT's Avatar
No they should not whine. I have installed two 4.10 ratio gear sets in Ford 8.8" differentials this year. First one was very easy, setup perfectly within spec and no whine. The second set I did were noisy on accel. and decel. This was due to incorrect pinion depth. I took at apart and corrected the pinion depth (had to move the carrier to one side) and now they are quiet.
The shop you are dealing with has done something wrong. Take it back and have them do it again. If your gears whine they are not setup right PERIOD.
If they argue and try to present the argument that all 4.10 gears whine you can tell them that many trucks come with 4.10 gears from the factory, for example all 4 x 4 Rangers come with 4.10's and an 8.8. Do you think they general public would accept gear whine in a new vehicle. I know I wouldn't.
Good luck!
Old Nov 12, 2007 | 09:36 PM
LEO_06GT's Avatar
I just got my 4.10's installed this past Friday and I don't have any whine. Your gear shop is full of it.
Old Nov 12, 2007 | 09:38 PM
GRAYPNY's Avatar
Ask the shop installer if he would like some cheese to go along with the whine? NO! They should not whine = poor install!
Old Nov 12, 2007 | 09:46 PM
fla.boy's Avatar
wow ! thanks! i was afraid of that! now that i think of it i have seroiuse whine when i let out of it! ok! not looking forward to dealing with the shop! the shop owner test drove my car today and when i mentioned the gear whine, he chuckled and said 'yeah thats 4.10s they whine' thanks again for all of your help! i may be looking for anther shop! thanks again!
Old Nov 12, 2007 | 09:58 PM
SoFlaBoss's Avatar
I had FRPP 4.10s and Detroit TrueTrac installed last Friday by Steeda and no whine!
Old Nov 12, 2007 | 10:00 PM
Lime GT's Avatar
I installed my frpp 4.10's and they are actually quieter than my stock 3.55's. The 3.55's had a very slight howl on decel only.
Old Nov 13, 2007 | 08:07 AM
RKNMACH's Avatar
No whine on my FRRP's - Did you have FRRP's installed?
Old Nov 13, 2007 | 10:57 AM
fla.boy's Avatar
Exclamation
yes! i had frrp gears put in. i talked to the shop owner this morning and i am going tommarow to the shop, so he drive it again. wish me goodluck! thanks for all of the replys and help
Old Nov 13, 2007 | 12:41 PM
LEO_06GT's Avatar
Don't look for another shop. Make them stand by there work.
Old Nov 13, 2007 | 03:00 PM
RKNMACH's Avatar
Ask them what backlash they put on it - I believe mine was .011.
Old Nov 14, 2007 | 09:19 AM
fla.boy's Avatar
Exclamation
ok! thanks! going to have them drive it again today. after talking to the shop owner again and telling him about the shuddering , he took an interest! i think he is realizing, whowever did the install may have screwd up. thanks for the help! will give update later.
Old Nov 14, 2007 | 12:40 PM
qwik huh's Avatar
I have seen a lot of issues with FRPP's new coated gears having more whine issues than the older ones have. The new ones carry an M at the end of the part number and have a chrome looking plating on them. I had an 08 in here the other day that we installed a set in. Backlash was good, pattern looked perfect, etc. Took it for a ride and the car had a decel whine at around 50 mph that went away around 30 mph. I tried making changes to the backlash and it did not change at all. I finally got fed up and grabbed another set off the shelf. Set them up as usual and they were quiet. Seems like Ford might be sub contracting out to the lowest bidder for gears now. I believe you can still order the 410A gears which are the original visteon Ford ones.
Old Nov 14, 2007 | 03:02 PM
fla.boy's Avatar
update! the shop owner and went for ride, when he heard all the noise from the back of the car he just shook his and said 'thats not good!' then he said he needed to check the gears himself and see whats going on. i am dropping the car off next monday. iwas glad to see him step up and do the right thing! hopefully he will get it right this time! however he did make the coment that it getting harder to find quite gears, whatever that means? anyway thanks again for allthe help! i will update when i get the car back on mondayor tuesday.
Old Nov 14, 2007 | 03:49 PM
LEO_06GT's Avatar
That's good. Just don't let them tell you whine is normal. That's total BS. When he said "it's getting harder to find quite gears" you should've responded with no it's getting harder to find someone that knows how to install them.
Old Nov 14, 2007 | 03:58 PM
tom281's Avatar
"Getting harder to find quiet gears" is a salesman's pitch........
Leo is right, the install is everything. I've had three different cars now in the past 5 years that I've had different gears installed, all of which were quiet. The constants between all three cars??
1) Ford Racing gears
2) Same install shop
And to be honest, I know many people that don't use Ford Gears but have had ZERO problems when the install is done correctly, which may rule out #1 above LOL. Just be polite with the install shop, but don't settle until they're quiet. And don't drive the car between now and when it's fixed, you could do MUCH more damage driving now until it's done right.
Old Nov 14, 2007 | 06:15 PM
281GT's Avatar
tom281 is right. Don't drive the car until it goes back to the shop. You don't want to wear the new gears in to the wrong pattern or it will be impossible to correct the problem.
Sounds like the shop owner is being good about it though.
Good luck!
(you'll love the 4.10s once you get them setup right!)
Old Nov 15, 2007 | 06:05 AM
RKNMACH's Avatar
I believe the M means they are made by Motive which hasn't gotten good grades in the past on this forum.
Old Nov 15, 2007 | 07:29 AM
fla.boy's Avatar
Exclamation
hi everyone!
thanks again for all the advice!
my immediate concern is the fact that this car is my daily driver. and i am supposed to go out of town this weekend , i will probably put 300 miles on the car over the week end. is this going to be a problem? thanks again
Old Nov 15, 2007 | 06:33 PM
281GT's Avatar
300 miles is not going to put any detectable wear on your gears but running them with an incorrect contact pattern is never a good idea. If you really have to make this trip I would suggest borowing or renting another vehicle and leave your Mustang parked until you can get your gears aligned correctly.
