Gas additives
Old Sep 1, 2007 | 04:37 PM
Adrenal's Avatar
Gas additives
What are your thoughts on gas additives such as Techron?
Old Sep 1, 2007 | 04:42 PM
MustangRetribution's Avatar
depends on what you mean by additives, are you talking about what major companies put into their gasoline or what you buy over the counter to help clean your system out.
Assuming that your speaking of over the counter additives, techron, imo is among the best. Every mechanic I ever talked to reccomends that stuff.
That being said, thats why I run chevron gas, the amount of techron in the gas is not meant to clean your engine but keep gunk from building up to begin with.
Alot of other gas companies, particurlary the "quiky mart" places typically use ethanol, which Im not a fan of running through my car even if only 10%.
Old Sep 1, 2007 | 04:50 PM
theedge67's Avatar
Techron is good stuff, I would stay away from the STP and Slick 50 type stuff. Those have caused issues with previous cars of mine in the past, notably eating up my spark plugs. A good dose of Techron treatment every 15,000 miles should keep everything nice and clean.
Old Sep 1, 2007 | 05:04 PM
don_w's Avatar
A detergent additive "may" keep things cleaner (well, at least that's what their commercials say, anyway), but I can't see how having a detergent in the fuel will help performance, except maybe on a stock or near stock car. Personally, I try to avoid gas that has additives in it. But, you never really know what's out there.
Old Sep 1, 2007 | 05:12 PM
ALL commercial gasoline companies put additives in there gasoline in some way shape or form.
Old Sep 1, 2007 | 05:51 PM
MustangLynda's Avatar
2 questions please and thanks -
Can I just add the techron to my gas tank (I'm not smart enough to mess with my engine)
What's the opinion on Sunoco gas?
Old Sep 1, 2007 | 05:56 PM
No messing with engines required, you just buy a bottle of the stuff dump it in with a full tank of gas
I dont know about sunoco, never seen a station here in cali
Old Sep 1, 2007 | 05:59 PM
karman's Avatar
#1-yes
#2-There are better ones.
Read throught this web site:
http://www.toptiergas.com/retailers.html
Check out the list and the explanations on the other pages.
They included Sonoco of Canada, but not USA yet.
Old Sep 1, 2007 | 06:03 PM
Funny how ford recomends BP and its not on that list
Old Sep 1, 2007 | 06:38 PM
poldrv's Avatar
Chevron Techron gleans the sensors in the gas tank. Using Techron eliminates DTI data fuel error messages.
Old Sep 1, 2007 | 06:42 PM
Adrenal's Avatar
I was thinking about this warning in the Operator's Manual:
Use SAE 5W-20 engine oil.
Only use oils “Certified For Gasoline Engines†by the American
Petroleum Institute (API). An oil with this trademark symbol conforms
to the current engine and emission system protection standards and fuel
economy requirements of the International Lubricant Standardization and
Approval Committee (ILSAC), comprised of U.S. and Japanese
automobile manufacturers.
To protect your engine’s warranty use Motorcraft SAE 5W-20 or an
equivalent 5W-20 oil meeting Ford specification WSS-M2C930-A. SAE
5W-20 oil provides optimum fuel economy and durability
performance meeting all requirements for your vehicle’s engine.
Do not use supplemental engine oil additives, cleaners or other engine
treatments. They are unnecessary and could lead to engine damage that
is not covered by Ford warranty.
Change your engine oil according to the appropriate schedule listed in
the scheduled maintenance information.
Maintenance and Specifications
202
Old Sep 1, 2007 | 06:47 PM
poldrv's Avatar
Hmmmm ...well Chevron Techron was recommended by the Flat Rock Plant Technicans after my gas tank had been dropped twice to fix the "DTI" data fuel error message. The dealer phoned Flat Rock directly for advice on the matter. The additional info was to use national brands only except Shell.
Old Sep 1, 2007 | 07:23 PM
don_w's Avatar
I like their 110 octane.
Old Sep 1, 2007 | 09:37 PM
goldenpony's Avatar
Techron
TECHRON is the ONLY additive that goes in my gas tank. I use a 20oz. bottle every 5K miles.
Old Sep 1, 2007 | 10:29 PM
karman's Avatar
202
That is about the oil, not the gas.
Do not put additives in the oil.
Old Sep 2, 2007 | 12:41 AM
+1 my automotive tech teacher biggest pet peeve was oil additives
Old Sep 2, 2007 | 05:39 AM
Driver's Avatar
Amsoil has a Product called PI I use it in all my Cars. Works well!
Old Sep 2, 2007 | 05:03 PM
metroplex's Avatar
Lucas Upper Cylinder Lube.
Old Sep 2, 2007 | 05:32 PM
The perfect example of a, "whats the point additive?".
then again thats just my personal opinion, but anything that lubes things to my engine that wasnt designed to be lubed I dont want in there.
Old Sep 2, 2007 | 06:04 PM
metroplex's Avatar
Well, contrary to popular belief, gasoline contains many additives that are designed to lubricate fuel system components. The ethanol they now use tends to wash down your cylinder walls and contributes to engine wear. More often than not, the standard fuel system is designed to run no more than 20% ethanol. Even the FFV systems designed to run E85 cannot prevent excessive engine wear from using E85 all the time. That is why you're not supposed to keep using E85/E100 and why you're supposed to alternate between E85 and regular gas.
Lucas UCL contains other additives besides an upper cylinder lube. So far, I haven't experienced anything negative from using UCL. It's not a solvent nor does it contain 75% kerosene like many of the other typical fuel additives.
