FRPP motorsport gears stink!
Old May 13, 2005 | 09:12 PM
169stang's Avatar
I will never use Ford Racing gears again! First set of gears were defective. They had a casting flaw in them. Now, I have 4.30's and broke them at launch. Busted a few teeth off. I will be going to Motive gears now. Very aggravating!
I guess the good thing here is that the rest of the driveline is holding up. Once I find gears, hopefully Motive, they'll hold up and then it's a matter of seeing what else is weak.
Old May 13, 2005 | 09:16 PM
O5GT's Avatar
i sell alot of gears, NEVER had a problem with motive gears, everything from drag cars to rock crawlers
NEVER a problem
Old May 13, 2005 | 09:42 PM
Sonic05's Avatar
I still can't believe the drive shaft is that strong. Way to go Ford! I had thought it would be the first thing to break.
I had heard someplace that the Ford gears are not that great. Guess they where right.
Old May 13, 2005 | 09:59 PM
169stang's Avatar
They are right. Those gears STINK! I'm just ticked right now. That's just one issue to go with the others. My suspension is still not right. I may need to relocate the LCA brackets. I also see that MMR now has a coilover. I'll be speaking with them on Monday! Once I get the car to transfer weight to the rear, I should get my times down a little more. I'm thinking of going to an electric water pump as well. After my last mods and dyno pull, I thought I was almost done...WRONG. Someone here did say to me that there will always be things to mod.
Old May 13, 2005 | 10:45 PM
wild stray's Avatar
David;
Have you checked your differential alignment since the sport springs were installed?
Paul
Old May 13, 2005 | 11:04 PM
Redfire1's Avatar
darn. I wonder if the stock 3:55 gears stink too. I dont roast the balonies very often, but I want to feel confident that I wont break the rear end when I do.
Old May 13, 2005 | 11:10 PM
O5GT's Avatar
ive been pretty hard on mine with no problems so far, the problems come in when you hook up, not from spinning
Old May 14, 2005 | 02:53 PM
169stang's Avatar
I trailered it down this morning. My buddy is very curious as to what is wrong. It really seems like the gears are gone, but when you drive it forward, you don't hear any consistant noise as if a tooth was missing. I had to use a cumalong to get it on the trailer. It would drive forward, but once I got to the trailer ramps, you could hear the gears slipping or jumping the teeth. Initiallly, we thought it was the axle, but after jacking it up, we couldn't get it to act as if the axle was busted. We'll see come Monday.
Old May 14, 2005 | 05:05 PM
Black Magic's Avatar
Could it be the transmission? Those gears should stand up to more torque I would think? I had a T5 bust before and the only way to move it was to push in the clutch and someone towed me home. It was a 8.8 rear with Motorsport gears that ran 7.33 in the 1/8th with a small shot of gas. Never had a problem with the gears but maybe you got another bad set. Let us know what's up and good luck.
Old May 14, 2005 | 05:49 PM
Mongoose's Avatar
Well you tires must be hooking up. You are sure hard on rear ends.
Old May 14, 2005 | 06:02 PM
SixtySix's Avatar
That's what she said
Old May 14, 2005 | 08:37 PM
169stang's Avatar
you are WRONG for that! lol. We haven't torn it apart yet and initially thought it was the gears. Then thought it may be the axles. I'm leaning towards my brand new Auburn Pro diff now being the culprit. I can actually drive it with out the consistant revolution/banging sound that a bad gear would make. 3 passes on the new diff. I think the spider gears are ate up. We'll see come Monday. I'm really not too sure what diff to go with. I've heard as many bad things about Eaton's as I've heard about Auburns (of course, after the fact). Some have mentioned Detroit EZ locker. I just don't want the clicking as I turn corners. Any suggestions....if it's actually my diff.
Old May 14, 2005 | 08:46 PM
Fordracing200's Avatar
i would use starnge rear end components or moser, never heard anything bad about motive though.
Old May 14, 2005 | 09:51 PM
RRRoamer's Avatar
169Stang,
I think that is called libel. You make a post about how crappy FRPP gears are and then post later that you think it might be the diff instead. Maybe you need to pull the rear end apart and find out what actually broke BEFORE you start screaming about thow crappy this part or that part is.
Good luck getting to the bottom of the problem.
Old May 14, 2005 | 10:35 PM
i have never heard or a FRPP issue, i would call them and address it if in fact it is the problem
Old May 15, 2005 | 06:46 PM
mikem's Avatar
I would get someone who realy no,s what there doing on the install.Way to much damage going on here for a car that only runs high 12,s.Many other 05,s are running right into the 12,s and beyond with stock gears.If you leave the stock 3.55s you wont need to shift into fourth gear.
Thats worth some tenths.I noticed when I ran my car, I was shifting into fourth right at the Traps.That was at 6000 rpm so I wanted to make my next run and let it go right thru the Traps in 3rd, But ran out of time and have not run my 05 again yet.
If pinion angle,Gear mesh,Backlash and Preload are not set correctly gear failure is certain.
Old May 15, 2005 | 07:42 PM
169stang's Avatar
Originally posted by RRRoamer@May 14, 2005, 9:54 PM
169Stang,
No, it's not libel when my first set of gears had a casting flaw in them. FRPP did give me another set of 4.10's when they have a 0 mile warranty due to the flaw. With a new diff. and a second set of gears, it sounded like the damage was in the gears. Yes, even now without knowing, have been premature in diagnosing the issue and premature in posting. It's just aggravating! I will know tomorrow. I'm sure you could understand my aggravation with another breakage. I'll be talking with some different people, manuf. and perf. shops to come to a conclusion.
It's really difficult to know what really works when you hear so many different, opposing opinions about parts. I hear that Eatons really stink, and they are the best. MMR racing states they won't ever use Auburn again, but have been running a Detroit EZ Locker for some time. This isn't just off the wall opinions. These are people that run these particular makes in their cars. I'll be talking to DTS (Drive Train Specialist) to see what they recommend.
I didn't set the backlash myself, but was there and watched my buddy set it to .010(10-1000th's). I haven't been racing for X amount of years or even more than 1 year to know what products hold up the best. I don't have the experience to say, hey, this particular brand is not good. All I have is what I can learn from you guys here, racer's, mechanics and just people with experience in drive trains.
Old May 15, 2005 | 07:54 PM
mikem's Avatar
Sorry Bud, for the problems you are having, but you realy shouldnt be having these problems at the point your at.Make sure you find out what the Preload and backlash numbers are suposed to be from Ford or the maker of the gears you choose.Also the depth of the Pinion gear must mesh corectly with the ring gear.I hope your freind is marking the gears with crayon or paint to see if they are meshing in the center of the teeth.When the crush coller is tightened you must check mesh.If you go to far you must get another one and start over.I strongly think your install is not 100% axles usually brake before gears.Sounds like the pinion gear is touching more to the outside of the ring gear.That number you said means nothing unless thats what Ford recomends.
Old May 17, 2005 | 07:01 PM
O5GT's Avatar
so what was broken?
