FRPP Lowering Spring Questions
Old Apr 18, 2011 | 03:43 PM
kenjo's Avatar
Just had my mechanic install my FRRP lowering springs. I noticed that the serial number for one (or maybe both springs; haven't found the other # yet) is upside down. Is this a problem? He also didn't take the small sleeve glued to the top of the stock spring top coil off and replace it on the FRRP's. I was wondering if this might be a problem, because when on bumpy roads I'm hearing a slight clunking sound from the rear suspension. I also had a steeda adjustable panhard bar and brace installed. I know this controls the position of the live axle, but it does move up and down a bit with the suspension. Any advice would be appreciated.
Kenjo
Old Apr 19, 2011 | 04:15 PM
D'prived's Avatar
Are you talking about the rubber sleeve that's glued to the bottom of the spring coil in the rears? If you are then yeah, it's a problem. The rubber sleeve is to insolate the two metals from rubbing together. That's probably where you're getting the clunking noise from.
Old Apr 19, 2011 | 06:50 PM
kenjo's Avatar
Thanks!
Thanks for the input. My pops said the same thing. I wonder if I'll be able to compress the spring enough to put the sleeve on without taking it out. We'll see.
Kenjo
Old Apr 21, 2011 | 03:04 PM
D'prived's Avatar
I seriously doubt you'll get the rubber isolater on the spring without pulling the spring back out. Good luck!
Old Apr 21, 2011 | 03:10 PM
ricksGT/CS's Avatar
just saying ,maybe its time you got a new mechanic ,or buy your mechanic some eye glass's ,
Old Apr 21, 2011 | 03:15 PM
ricksGT/CS's Avatar
Talking
Old Apr 21, 2011 | 03:20 PM
ricksGT/CS's Avatar
Talking
FRPP Lowering Spring Questions-323470-r1-15-14a.jpg just trying to show you how the rear Ford Racing springs are suppost to look ,
5.M0NSTER
26
Sep 28, 2015 07:11 PM
RocStar69
Aug 21, 2015 07:33 AM
