Forged internals
Old Oct 16, 2012 | 09:08 PM
claypops's Avatar
Forged internals
I am dropping a 4.6 in my mustang. But building it from intake to oil pan. What is a good site to get forged internals? (Pistons, rods, crank, etc.)
Old Oct 16, 2012 | 09:27 PM
Old Oct 16, 2012 | 09:31 PM
dly's Avatar
dly
http://www.brenspeed.com/05-08-musta...ne-engine.html
Old Oct 16, 2012 | 09:57 PM
muscledom's Avatar
That's awesome man. Wish I had the time to do the same :'(
Old Oct 16, 2012 | 10:02 PM
except that brenspeed tune.
no answer to high altitude issues on the 4.6.
no answer to the #8 failure in the 5.0.
Old Oct 17, 2012 | 04:40 AM
Scott2's Avatar
I too have a Forged Engine build underway with associated driveline mods. Once you get going you will figure out that the "(Pistons, rods, crank, etc.)" list is a pretty long one. Clearly the "etc." will fit you in the pocket book. Here is my current parts list which grows daily as you plan your build:
Ford Racing Performance Parts Aluminator Engine Build – Winter 2013
• FRPP 4.6 Liter Aluminator Short Block 9.8:1 Compression Ratio, M-6009A463V – Inventory
• FRPP 4.6 Liter 3V Performance Intake Manifold, M-9424-463V – Inventory
• FRPP 4.6 Liter 3V 62mm Billet Throttle Body, M-9926-3V – Installed
• FRPP High Flow Fuel Injectors, Flow Rate 60 lbs/hr @ 39.15 PSL, M-9593-LU60 Inventory
• FRPP CNC Ported 3V Cylinder Heads , M-6050-N3VPA (LH) and M-6049-N3VPA (RH) - Wish List
• FRPP Performance Head Gaskets, M-6067-3V46 - Inventory
• FRPP High Performance Oil Filter, M-6731-FL820 – Inventory
• FRPP 3V Header Gaskets, M-9448-A463V - Inventory
• ARP 4.6L 3-Valve Head Studs, 256-4202 - Inventory
• Moroso Performance Parts Ford Modular 7qt Capacity, 6 ½” Deep Sump Oil Pan, 20548 - Inventory
• TSS 3V/GT500 Oil Pump Assembly w/ Billet Gears - Inventory
• Ford OEM Oil Pan Gasket, 3L3Z-6720-AA - Inventory
• Vortech 6 Rib Supercharger Pulley (2.87”), 2A036-287 – Ordering Pending Confirmation of Sizing
• Comp Cams 4.6L Modular 3V Ford 2005 & Newer Cam Phaser Limiter Kit, 5449 - Wish List
• Comp Cams Beehive™ Valve Springs: Top 1.013" O.D., .650" I.D.; Bottom 1.101" O.D., .738" I.D., 26125-24 - Wish List
• Comp Cams XFI™ SPR Ford 4.6L/5.4L Modular 3V Cams (Springs and Phaser Modifications Required), 127550 - Wish List
• Comp Cams 7 Degree Steel Retainers: .959” Spring Diameter, 710-24 - Wish List
• Ford OEM Cam Phaser Bolts, 2 @ 3L3Z-6279-DA - Inventory
• Ford OEM VCT Housing Gaskets - 3L3Z-6C285-AA Right Hand and 3L3Z-6C286-EA Left Hand - Inventory
• Ford OEM 2 Valve Steel Bodied Tensioners, F6AZ-6L266-DA Right Hand and F6AZ-6L266-CA Left Hand - Inventory
• Ford OEM Timing Cover Gaskets, 4R3Z-6020-BE, 4R3Z-6020-DB, 4R3Z-6020-EB - Inventory
• ATI Harmonic Balancer – ATI Super Damper Serpentine Series, 918039 – Inventory
• ARP Harmonic Damper Bolt, 156-2501 – Inventory
• Ford OEM Crankshaft Key, FLAZ-6B316-AA – Inventory
• Ford OEM Front Oil Seal, XW4Z-6700-AA - Inventory
• PRW SFI 3V 8-Bolt Flexplate - PRW Platinum Series SFI-Rated Steel Flexplate, 1828111 – Inventory
• ARP Flexplate Bolts (8), M10 x 1.00 (UHL .800), 254-2901 – Inventory
• UPR Billet 3 Bolt Tensioner and Custom Billet 76mm Tensioner Pulley - UPR 3030-02 and Carmen Goudey S197 76mm Pulley - Installed
• ARH Mustang 3V 2005-2010 Stainless Steel Headers1 ¾” Primaries w/Catted X-Pipe, MST0634WC - Installed
• Mangnaflow Ford Mustang GT, Shelby GT500 3 inch Cat Back Exhaust, 16674 - Installed
• Stage 8 Stage 8 Locking Header Bolt System 8mm, 1.25x22mm, 8906M – Inventory
• Circle D Specialties Multi Disk Performance Torque Converter - Wish List
• Performance Automatic 5R55 Deep Aluminum Pan and Filler Tube Set , PA27455KT – Installed
• Performance Automatic Transmission Input Shaft for Ford 5R55S, PA27406 – Inventory
• TCI Auto StreetFighter Ratchet Automatic Shifter, 619570 – Installed
• TCI Auto Hi Performance Transmission Servo Kit, 3rd Gear Servo Kit, 576005 – Inventory
• TCI Auto Hi Performance Transmission Servo Kits, 4th Gear Servo Kit, 576006 – Inventory
• Canton Racing Products Automatic Transmission Expansion Tank, 45-000 – Inventory
• B&M Racing and Performance Products Hi-Tek Transmission Cooling System, 70297 - Inventory
• Hypertech Power Stat 160 Degree Thermostat Mustang GT (05-09), HYP1011 - Inventory
• Metco Motorsports Four Piece Idler Pulley Set, MIP-2005 - Inventory
Old Oct 17, 2012 | 05:50 AM
CCTking's Avatar
My mouth just dropped an inch for everything on that list.....
Old Oct 17, 2012 | 02:52 PM
claypops's Avatar
Mine too
Old Oct 17, 2012 | 04:54 PM
cpotts13's Avatar
Pics or BS.
Jk
Nice list!
Old Oct 18, 2012 | 08:50 AM
Scott2's Avatar
Originally Posted by cpotts13
Pics or BS.
Jk
Nice list!
Not BS, don't want to muck up Claypops thread, but I can provide pictures of everything in "inventory" except for the Aluminator as it is in shop storage.
I did pick up these parts on Oct 15th:
Metco 4-Piece Billet Idler Kit, 2005 - 10 Mustang GT 3V, MIP-2005
ATI, Super Damper Serpentine Series, 918039
And I ordered this today because of the free shipping to Canada:
http://www.cjponyparts.com/ford-raci...0/p/M6004463V/
Old Oct 20, 2012 | 12:41 AM
claypops's Avatar
Any idea what you run at the track with all that?
Old Oct 22, 2012 | 06:26 AM
Scott2's Avatar
No idea, but I am targeting for 550 to 600 HP at the wheels.
Old Oct 23, 2012 | 11:47 PM
claypops's Avatar
With all my plans I plan on putting 900hp from the motor. It's just going to take a while. And lots of money. I just hope to get there soon
Old Oct 24, 2012 | 05:15 AM
Scott2's Avatar
900 HP on the street, WOW that is a very aggressive goal!!! I am not sure that it can be done on pump gas? Do your plans call for a return style fuel system and alternate fuel?
Old Oct 27, 2012 | 03:01 PM
claypops's Avatar
Ya that's my goal. But like you said it's an aggressive goal. I don't know a whole lot about fuel systems. If it can't be done on pump fuel then I probably won't get 900. I'm in a v6 now so anything is a big jump. But I want to do it right before I drop it in. I guess I'll see what 25 pounds of boost gives me before I mess with the fuel systems
Old Oct 28, 2012 | 10:46 PM
Planeswalker's Avatar
How close are you to being done, would love to see end results!
Old Oct 29, 2012 | 02:21 PM
Imatk's Avatar
900 hp on the street would be pretty useless, unless you like to spin the tires a lot.
You also might want to look into chassis stiffening with that kind of power, I don't know what the v6 chassis is rated for but 900 is pretty insane.
I'm in the mid 600hp range with my GT500 swap and first gear is completely useless if I stomp it. Hell second gear is too come to think.
It's fun as hell, but just be careful with that much you're going to find traction a real problem.
Old Oct 29, 2012 | 02:42 PM
claypops's Avatar
Ya I mean once I get it dropped in, it's definitely not goin to be pushing 900. That's just what I'd like it to be at eventually. To get that much on a dyno I would probably have to be pushing a lot of boost and a shot of nitrous. And what have you done to the GT500 motor?
Old Oct 29, 2012 | 02:45 PM
retfr8flyr's Avatar
For that kind of power you are better off going with a return style fuel system. Talk to these guys http://www.sandhperformance.com/?page_id=48 and they can build you a system for your needs. You will also need a much better transmission and rear end to handle that kind of power.
Earl
Old Oct 29, 2012 | 03:04 PM
Imatk's Avatar
GT500 motor is stock. But added a bigger blower and upgraded HE.
