Flashing computrt for 4:10 gears
Old May 6, 2005 | 06:58 PM
Mongoose's Avatar
I installed 4;10s and the speedometer is 10 MPH off. Understood! Asked dealer to flash computer for rear end change and he said he could not.
I have a predator and did flash it for the performance tunes but lost it when I went back to stock tune.
Need Help. What is the whole true story?
Old May 6, 2005 | 08:29 PM
somewhatdamaged's Avatar
Which Predator do you have? If it's the Diablo, just download the latest revision from the website if you havn't already. The gear change option is there, within the tunes i believe. Good luck!
Somewhatdamaged
Old May 7, 2005 | 09:06 AM
tmcolegr's Avatar
Make sure you are using the latest version of DS Downloader - version 1,2,6,0.
The older version 1,0,1,0 will not allow the paramater to be changed after installation.
Old May 7, 2005 | 08:05 PM
Mongoose's Avatar
I have the latest at the time March 05 but without all the new revisions.
Are you saying the dealer does not have the capabilities to change it?
Thanks for your help.
Old May 8, 2005 | 04:37 AM
tmcolegr's Avatar
That is correct - the dealer can not change it? Their software will not allow them to change the gear ratio as the change is not "EPA Approved" by Ford.
Old May 8, 2005 | 09:49 AM
Mongoose's Avatar
Thanks I will do it today. Shift points are all screwed up also with the 4:10.
Old May 8, 2005 | 02:52 PM
tmcolegr's Avatar
Which Predator do you have - DiabloSport, C&L or Steeda. Which release revision are you using? What version of DS Downloader do you have? What is your CALID? What tune are you trying to install and calibrate for the 4.10 gears?
Rando
Aug 25, 2021 11:12 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
Rando
Sep 30, 2015 12:28 PM
Airborne42
Sep 24, 2015 10:27 AM
