First oil change (what's everyone using?)
Old 5/12/06 | 02:55 PM
OKLACOP's Avatar
I'm about to do my first oil change. What is everyone using?????? Should I go with Ford's recommendation or has someone found something better? I did a search for this topic and found nothing so I'm sorry if this is a repeat question.
Old 5/12/06 | 02:58 PM
freebass55's Avatar
All I have ever used on my vehicles is Mobil1.
Old 5/12/06 | 03:03 PM
Lowe!'s Avatar
Mobile 1 5W-20.
There used to be PLENTY on threads about this, but since the migration, who knows.
Old 5/12/06 | 04:13 PM
RPM's Avatar
RPM
You really can't go wrong with Motorcraft 5W20 and a shiny new FL820S. If you want to do extended OCIs then Amsoil or MOBIL 1.
Old 5/12/06 | 04:42 PM
70MACH1OWNER's Avatar
DITTO!! on the MOBIL1 5W-20
Old 5/12/06 | 05:44 PM
OKCMustangGT's Avatar
I changed my oil the first time at 200 miles, used Motorcraft 5W-20.
Changed again at 1,000 to what will be in it for the remainder of it's life
MOBIL1 5W-20
Old 5/12/06 | 05:54 PM
os121's Avatar
Another w/Mobil 1 (*)
(*) first 2-3 changes were w/the motorcraft, and switched to Mobil 1 at 7k.
Old 5/12/06 | 06:33 PM
1200custom's Avatar
My only oil change so far was free, The dealer used motorcraft, I was told it was a synthetic blend.
Old 5/12/06 | 06:45 PM
Ranger's Avatar
I let the dealer do my first change. The ford oil is a blend which, depending on who you ask/what you read is as good as a synthetic or not. After the first change, switched to Mobil 1
Old 5/12/06 | 07:13 PM
RPM's Avatar
RPM
I have read but have no personal experience that would either verify or indicate otherwise that the oil-pressure-sensitive VVT relies on the viscosity of 5W20 to work correctly. So to that extent "they" say to stick with a 5W20 regardless of brand and that 5W20 should meet Fords' specification. After that it's just a choice of availability, cost and "feel good" factor.
Old 5/12/06 | 08:00 PM
traffic142's Avatar
Heck, I went with the free first one also. Plan on after that using mobile 1
Old 5/12/06 | 08:14 PM
NJ3's Avatar
NJ3
Same here.
Old 5/12/06 | 08:28 PM
hk2006's Avatar
you should wait 7-8K miles before switching to synthetic to let the engine pass break in period with regular oil
Old 5/12/06 | 08:52 PM
GRAYPNY's Avatar
I went with 5-20 Mobil 1 on my first change and I use a Ford Racing oil filter #FL820. I don't drive my car enough the worry about the miles so I bought 3 filters and will change the oil every 4 months.
Old 5/12/06 | 10:34 PM
Badsnke98's Avatar
Change it if you want, but if you are not putting on many miles as I, it is not necessary.
To answer the orignal poster, Motorcraft 5-20 blend is just fine for the 3-V. Mobil1 is fine after you past 5K miles, but only if your going for extended mile use, otherwise just like useing 93 octane without a tune, just wasting money.
Old 5/13/06 | 01:11 AM
TombStone's Avatar
Royal Purple 5W-20. A little pricey, but well worth it for my baby.
Old 5/13/06 | 02:39 AM
LordBritish's Avatar
Amsoil XL 5W-20, change every 10,000 miles.
Also use Amsoil oil filter.
Amsoil's 2000 series is good for 35,000 miles, so they claim. I have not put it to the test. Somebody let me know if this claim is true.
Old 5/13/06 | 08:36 AM
bigaloz's Avatar
mobil 1
Old 5/13/06 | 08:12 PM
red454's Avatar
Amsoil 5W20 and Amsoil Filter at 3000 (first change).
Change interval will be 7500 miles...
Old 5/16/06 | 08:38 PM
1 BAD 05's Avatar
Mobil 1 5-20 with a Mobil 1 synthetic blend oil filter M210
Quick Reply: First oil change (what's everyone using?)
