Factory service and custom tunes?
equip: 06 GT, C&L CAI, XCAL2 -93 oct flash., flowmasters
Wondering if others like to reflash back to stock before taking their cars in for service.
Simple enough to do- my concern is that a check engine light will come on because of the Air Fuel being wrong (due to the CAI).
What can I do?
Can FORD void my warranty if I leave a custom tune loaded?
btw- the service I need done is NOT engine related....
What can I do?
Yes, Ford will probably void your warranty. You're worried about the air/gas mixture with the reflash and the CAI. Well, there is another issue...the CAI. They can void "it" for "that" as well. To be safe, you should reflash and remove the CAI(Reinstall factory intake) before you take it in. You're OK with the Flows.
They can't void your warranty, period. That is a blanket statement. If a particular system fails, and they determine your mod to have been the cause of the failure, they can refuse to cover * that instance *. They can't just say "hahaha no more warranty for you!! "
I have the same relationship with my dealer even though they are not an "SVT" dealer. If you start changing cams and doing head work etc. then you might have a problem. Be up front with them and find out for sure.
NO dealership can void a factory warranty, without authorization from Ford corporate in Detroit, also Ford has to prove within a reasonable doubt that the aftermarket tune or part was directly responsible for the warranted part in question to fail..Otherwise it is illegal to void a factory warranty for just the sake of installing an aftermarket part..BTW, this information is direct from a Ford field service engineer and not from me.. with that being said ? being that your also from Pittsburgh ?? I'm quite sure your familar and know where Kenny Ross Ford is located ?? I take my Stang there all the time to be worked on and there's never been a problem with my Steeda CAI and SCT tune..In fact the technician that works on my Stang has installed both the FRPP cold air intake, FRPP stinger axle back exhaust and FRPP shorty headers for several other customers as well..You only need to reflash back to stock, if your PCM files need updating by the dealership in which I always take my SCT tuner just in case there's an update that's required..Kenny Ross Ford, is also a Roush Dealer as well..
![Blah](https://themustangsource.com/forums/images/smilies/blah.gif)
Actually most CAIs that include a non-factory MAF should technically void your warranty because:
1). It requires modification of the PCM calibration to work properly
2). It can cause emissions equipment failure (incorrect air transfer function = melted/clogged cats)
3). The CAI kit aren't all simply air filter replacements. If that MAF is replaced, it is a totally different story. The FRPP kit includes a tuner that flashes your PCM with a new tune that includes the correct air transfer function (non-authorized modification of PCM tune and non-authorized electronic engine control device being used).
That's my take on it and I'm sure most dealerships won't void your warranty because it is a Mustang GT and because a CAI kit makes it kick even more a$$ on the track.
I would take it back to stock (minus the axle backs) just to avoid the hassal if they do have an issue with it. Not like it takes long to put the stock air intake back on and re-flash it.
Dealers around me all have sign's up noting that they will void warrentys if there are any modified parts.
I'm sure that it'd be hard to actually get something in writing saying that an aftermarket Steeda CAI kit won't void the Ford factory warranty, but most dealerships would *probably* let it slide.
We have dealers that carry Steeda parts and are listed as Steeda dealers. They also install the parts to include CAI's. Steeda's web site lists them as licensed by Ford and as a "Partner in Performance". I would think it would be hard to void the warranty...
The key thing is to get something in writing because you never know what might happen and a dealer will refuse warranty service.
Again, it all depends how you drive your car. Hard to see how the installation of a CAI will cause any engine problems unless you keep tinkering with it by changing the tune. Most users who "hot rod" on the streets shouldn't get to the point where the engine is put under so much stress it will have parts fails.
If you use an aftermarket MAF + aftermarket CAI kit, you will need a tune or else you will run excessively rich or lean and cause catalytic converter failure and/or engine damage.
Steeda does advertise that you need a tune because of the change in MAF. I just chose to go with Doug's tune which takes the Steeda set up in consideration. There appear to be many other systems CAI available but I chose to go with one that seems to be in bed with Ford. The system works fine for me and has not created any problems so far.
