Exhaust hanger problem...
Old Jul 24, 2008 | 01:45 PM
acascianelli's Avatar
I finally found out what was wrong with my O/R X-pipe. One of the hanger posts on the midpipe is in the wrong position and is hitting the metal part of the hanger on the transmission cross member. I had read in another thread that some GT''s have the hangers on the crossmember removed as part of a TSB that was issued. My question is, could I just cut the hanger post off the X-pipe and just leave the driver side one on there. Would it flex too much, and is it a bad idea to have the whole pipe being held up by the rest of the exhaust system.
Old Jul 24, 2008 | 03:42 PM
presto's Avatar
The hangers on the trans support are used only in the factory for assembly. The Ford tsb says to remove the mounts and bend the pipe mounted hangers down until they're level with the ground, but I just cut the hangers off of my stock h pipe totally.
Old Jul 24, 2008 | 08:49 PM
Redrocket06's Avatar
The O/R H that came with my LT's the hanger rubbed too, this is what I did...
https://proxify.com/p/011010A0000110...6/DSC01050.jpg
hope the link works.
Old Jul 24, 2008 | 08:51 PM
Good it worked. Here is another view:
https://proxify.com/p/011010A0000110...6/DSC01049.jpg
Old Jul 25, 2008 | 11:27 PM
The links don't work.
Old Jul 26, 2008 | 01:37 PM
I will have to try to load them at home. You can also find them in the thread 'Pulled Trigger on LT's'. I think they are on page 11.
Old Aug 1, 2008 | 05:11 PM
I just wanted to update this thread with the solution of the problem I was having. I ended up having to remove BOTH hangers for the trans crossmember, both of them were contacting the brackets.
Sep 24, 2015 08:15 PM
Sep 10, 2015 12:44 PM
