Exhaust Delima
Exhaust Delima
currently I am running all stock exhaust with flowmaster ATs. I like how they sound however they are just not loud enough. I am afraid going to a OR/H will make it to obnoxious as a daily driver...its hard to tell from the sound clips how it really is.
just curious what some of you think I should do?
again I like how my flows sound however they seem a bit tame...I would like something that will turn a few heads..
Scrap the flows and start with another set of axle backs?
get a high flow cat H or X setup with the flows? assuming this will give it a nice boost in sound?
go with a or/h and say screw the neighbors..(just seems like some of th OR/h flow clips i have heard sound a bit like a tin can at times).
Keep the flows and add LTs..and a CAI/tune (wondering if this wont make it significantly louder as well).
thanks!
thanks!
DOn't go with an O/R H or X if you are worried at all about emissions or noise ordinances. The clips don;t do it justice, it is like driving a Harley, and you get alot of raw exahust smell in the car too. If you want loud, go with FRPP Stingers. If you want loud without drone, drop the bucks on a Corsa setup.
there aren't any mustang clubs in your area? that would be the best way to hear different set-ups.
personally, i agree that the flowmasters are too quiet. i got the stingers and i am pretty happy with them. very agressive sounding. just gotta dynamat the trunk and under the seat to control the drone.
what is the difference between a OR prochamber and a OR/h?... is it sound and or performance? Is the prochamber deeper then a H?
I do not know much about prochambers...and if one was catted, would it be any different then my stock h pipe?
I also wonder if getting the catted H from someone like MRT would be any louder then my stock H.
Well, I had the flows and felt the same way. So I went with the O/R H and liked it. But it was on the loud side, and waking up the household seemed to be an issue too, lol. I also would wake up about 50 others. Animals in the woods across the street that is.
So eventually the flows rotted out, and I tossed the stock mufflers back on and its a happy in between for me. Just had to add the 4" tips.
I hear good stuff about sonicboost's recommendation too. I think its better to hear the setup in person 1st if at all possible.
on a number scale can you give me some kind of idea how much louder it is? I assume the stockers mellow it out quite a bit, and do you still have a nice raspy sound on decel and when you rev it?
you know I have heard a few clips of a or/h with the stock mufflers and I think it sounds pretty good...I assume you like it since you run it.
Yeah, you still get the gurgle when cruising to a stop.
I would say its about 20-40% louder than just the flows.
http://www.youtube.com/watch?v=RkrvY_OZhLA
I have the Flows with Bassani LT's and Bassani OR x-pipe. I like the sound but it is not quiet by any means. It is however not as loud as my harley so my neighbors are just happy I am not driving that. If I could do it again I would have got the high flow cats since the OR pipe doesn't add much power. I think the a high flow catted x-pipe with the stock headers would have a good bark without being too loud.
I would recommend the O/R pipe. Your foot is what controls the loud meeter. I have a prochamber and it acts like a muffler. It made my car quieter. I then went with off road pipes for it and now I think it's perfect. The rest of the exhaust is stock even mufflers.
The reason I know, is I recently upgraded to a Prochamber with high-flow cats, and my Pypes Violators now sound deeper, plus they no longer drone anymore.
What are good tips to add?
Brenspeed says that the OR/H gives you 10HP, I believe them because eliminating the cats must free up some HP, 5-10 sounds right. Can anyone confirm?
Want to make your Flowmaster's a little louder? Just cram two cubes of butter in each of the tailpipe as far as you can get them in there, and take a long trip. The butter will burn-out your muffler packing, making them louder.
I have heard the old "fill your mufflers up with water" trick.. but never butter. Interesting..
I'm going this route, will install the o/r to the stockers within the next month, heard quite a few clips that sound very good and no drone
Yep, I tried that with my Pypes Violators. The water causes that nasty backfiring sound upon letting off the throttle. Once the water drained out, the sound disappeared and was replaced by a nice gurgling effect.
