Estimate of time/tips to install CDC shaker
Old Apr 7, 2007 | 05:34 PM
kennyg's Avatar
I've just read the installation instructions for the CDC shaker for the '05-'07's and was curious as to how much time was required from start to finish on this project. Anyone that has installed one, how long did it take you? Thanks for any info or tips. kennyg
Old Apr 7, 2007 | 05:57 PM
tom281's Avatar
There's lots of info here...... if you search alittle bit, you'll find all you need to know.
In short, I'd give the job a three beer difficulty rating and it took me about three hours.
Old Apr 7, 2007 | 06:06 PM
atomic_il's Avatar
http://forums.bradbarnett.net/showpo...88&postcount=1
Old Apr 7, 2007 | 07:54 PM
See OKCMustangGT's Shaker install post, has some helpful info.
Like Tom estimated, 3 hours sounds about right.
Going from memory, Don't permanently tack the upper trim ring down on the hood until you prefit the shaker shroud. The center of the shaker scoop vertical rib should be inline with the hood centerline. The shaker shroud has limited side to side adjustablility, but if you cut the hood hole crooked to start, adjusting the upper trim (has some float in it within the cutout) last to center it to the scoop will help. Trust me.
Old Apr 9, 2007 | 12:34 PM
kennyg's Avatar
Thanks for the tips and other info. Talked to the owner today and he will bring the Stang out later in the week. Those 3 beers will come immediately after the successful install! kennyg
Old Apr 9, 2007 | 12:55 PM
tom281's Avatar
hahaha OK, let us know how it turns out.
Old Apr 9, 2007 | 05:26 PM
70MACH1OWNER's Avatar
While I agree with your 3 hour time table. That 3 beer difficulty rating seems a little low to me. Took me at least 3 to get up the nerve to drill that starter hole. After that it was easy.
Scott
Old Apr 9, 2007 | 05:51 PM
aircare84's Avatar
My install took about 6Hrs, but I didn't hurry.
I did read about everything I could find prior though, helped quite a bit.
Old Apr 9, 2007 | 06:22 PM
fxdwg2002's Avatar
Measure a dozen times and Cut once!
