The end of an engine's life?
What is usually the cause of a broken engine that is supercharged?
I'm sure it can be many things, but is there something common, like the pistons/crank/rods get damaged(which can be replaced without needing a new block) from years of forced induction? I'm just wondering cuz if I decide to SC my stang, I was wondering how much the damage would be to fix or would I need a new engine w/ a new SC or the old SC?
So far, the most common failure with the 3V engines have been the powdered rods. And almost always, once a rod snaps, it tears up a lot of stuff.
The rods,
If the rods let go your internals are gonna look pretty much like meow mix.(the dry kind).But you can save alot of the external stuff.
Tuners are pretty much up to snuff with tuning S/C's now.
But its been said many times in these forums..........if ya gonna play ya gotta...........
Originally Posted by don_w
Whats that? The oil pan?
I have a couple of friends who have force fed cars and had to use the pans to collect parts. Both of which have since been rebuilt solid and run like monsters.
Originally Posted by 06GTwBOOST
Thats the rod/piston collection pan. It's mainly used to collect the pieces of your internals so that they dont litter the highway and streets where your engine decided to destruct.
Do they usually rebuild their engine with the same block? Can they still use the same supercharger that was on the old engine? Are the only things they had to replace the connecting rods and pistons?
BavarianStang
Sep 5, 2015 05:55 AM
Mackitude
Aug 17, 2015 04:14 PM
