Eibach/Steeda Rear Springs Only Questions
I have the Steeda springs all around so I don't know exactly what it'll do with only the rear dropped but you definitely don't need an alignment with just a rear spring swap. I drove around for months after installing my springs without getting it aligned and didn't have any issues.
The one thing I can tell you though is that without replacing the shocks it gets a little bouncy over expansion joints due to the firmer spring rates. I would also suggest an adjustable panhard bar to recenter the rear axle after lowering. It isn't imperative to get one but it is suggested.
Sorry for the bad pics due to the sun/
Also- which rear panel cover is that on your rear decklid- I really like it!
I agree with you about the extra firmness over expansion strips- I really didn't notice it at first, but now that I have been driving it on the freeway, it is a little bothersome. Will new shocks/struts cure this problem? Or is there no really excellent shock set-up for the Steeda Ultralite springs?
