Earls SS brakes lines
Old Nov 3, 2005 | 08:56 AM
FordRacing's Avatar
Earls SS brake lines
http://www.semaphotos.com/imageSingle/Imag...EM2005110100199
Old Nov 3, 2005 | 12:12 PM
Mongoose's Avatar
Why would you need or want this? :scratch:
Old Nov 3, 2005 | 12:19 PM
MTAS's Avatar
They don't expand under pressure like rubber hoses. I had them on my 96GT and they made a noticable difference in pedal feel, for the better.
Old Nov 3, 2005 | 12:20 PM
Trampus's Avatar
For maximum blingage?
Unless you've done some type of super brake upgrades, I don't see why the stock lines aren't good enough.
Old Nov 3, 2005 | 12:26 PM
Cleveland's Avatar
You folks apparently dont use your brakes a lot to know it would make a difference.
-Dan
Old Nov 3, 2005 | 12:32 PM
FordRacing's Avatar
What he said
I bet they are going to be a lot cheaper then Steeda's too...
Old Nov 3, 2005 | 01:04 PM
Ascout's Avatar
-Dan
What he said. Braided steel lines contain and prevent expansion of the "rubber" lines within, resulting in a profound difference in the feel of the pedal (or the lever, in the case of motorcycles, where it's even more noticeable, given that you are using your hand).
They modulate much better, take less effort (in a hydraulic system, some of the energy you are inputting is to "expand" the lines, when they aren't solid or braided steel), virtually cannot rupture, and look beechin'!
By the way, Earl's are great places for various gearhead stuff, racer and amateur alike. Lotsa' hard to find stuff not carried at your average parts store.
Are the Earl's lines their own, or made up for them by Russel's and sold by Earl's (as I'm used to seeing....)
Old Nov 3, 2005 | 01:47 PM
MTAS's Avatar
Originally posted by FordRacing@November 3, 2005, 3:35 PM
Aw come on man, are you for real? Steeda have high prices? No way Just because they charge nearly $9 to ship a billet aluminum power plug-in thing that would fit in a padded envelope and be mailed for $2, doesn't mean they have high prices
/sarcasm off
Old Nov 3, 2005 | 01:59 PM
dustindu4's Avatar
9 is not my lucky number.
Wouldn't these make it easier to hook up line locks? You wouldn't have to bend and flare your own tubes?
Old Nov 3, 2005 | 02:15 PM
FordRacing's Avatar
I one word....
YES
Old Nov 3, 2005 | 02:17 PM
FordRacing's Avatar
/sarcasm off
I bought a couple things from Steeda a while back I will never buy another thign from them :bang: Over priced and the quality isn't very good IMO.
Old Nov 3, 2005 | 02:32 PM
Cleveland's Avatar
Earls makes their own stuff, they do not out source. I use Earls fittings and there is a difference between their stuff, Aeroquip and Russels.
Also, Russels is an Edelbrock performance brand and Earls is of Holley.
-Dan
Old Nov 3, 2005 | 02:50 PM
Ascout's Avatar
-Dan
I asked, because I've gotten Russell's stuff at an Earl's before, as well as steel lines for compression fittings for my motorcycle. Specifically, the Earl's up in Vista, CA. They may make what they package as Earl's, but they do handle other lines in my experience.
Old Nov 3, 2005 | 03:39 PM
dustindu4's Avatar
Originally posted by FordRacing@November 3, 2005, 4:18 PM
I one word....
YES
Well that's good because now we can use these and buy a $130 line lock kit from Jegs instead of buying that dumb $300 05 specific kit
Old Nov 3, 2005 | 04:04 PM
FordRacing's Avatar
Yeah but you would still have to find the right adapters, which as I understand it is the hard part.
Old Nov 3, 2005 | 04:26 PM
Ascout's Avatar
...and apart from any adapter issue, be sure you get some clips to secure the lines...away from anything you don't want "sawed". Abrasion from steel braided lines is pretty much like a flexible rat-tail file. And keep in mind that you can't make tight right angles.
(I have split-loom around the braided lines on my motorcycle at all possible contact points, as I did oil lines also...brake stuff may already have a coating in kit form)
Old Nov 3, 2005 | 06:55 PM
Mongoose's Avatar
-Dan
You are correct in my case. I just throw a chute out the window at the end of the quarter..
Old Nov 3, 2005 | 07:00 PM
don_w's Avatar
$130 plus whatever the SS line kit and fittings cost... you may not save much. Is the $130 Jegs kit OK for ABS?
Old Nov 3, 2005 | 08:54 PM
slammer223's Avatar
I won't stop till I have a set of these on my Stang.
Old Nov 3, 2005 | 10:14 PM
Cleveland's Avatar
As if I needed more stainless steel braided hose...
-Dan
