E 85 conversion
Old Nov 22, 2015 | 06:38 PM
s197's Avatar
E 85 conversion
What is all needed to switch over to E85
Old Nov 23, 2015 | 11:26 AM
07 Boss's Avatar
Bigger injectors and a tune. You might need to up your fueling capacity.
Old Dec 25, 2015 | 05:34 AM
s197's Avatar
BAMA Performance Common Questions Top Questions
CAN YOU TUNE FOR E85 OCTANE?
We currently offer E85 tunes for the 2005-2015 Mustang GT, V6's, 2003-2004 Cobra's and 2007-2014 GT500's. Running E85 in your Mustang requires some upgrades to your fuel system. Because of the complexities involved in switching to E85 fuel, we recommend that you call and talk to one of our specialists about your plans.
Please be advised that because E85 burns over 30% richer your fuel economy will drop drastically.
We advise purchasing an Ethanol content tester and validating the % of ethanol before use. If you plan on storing your vehicle and not driving every day, the Ethanol will "gel" inside the fuel tank and injectors and cause poor performance.
2003-2004 Cobra
Please contact a Bama Tuning Specialist to discuss your specific application/power output for pump/injector recommendations.
2005-2010 Mustang GT/V6
47lb or larger fuel injectors
Stock Pump
Forced Induction Vehicles require larger than 47lb fuel injectors and a fuel pump upgrade (Stock pump and BAP are not large enough)
2007-2014 GT500
Injector Dynamics ID1300s
Return Fuel System with Dual or Tripple pumps
2011-2015 Mustang GT/V6
Stock Pump
Because E85 requires a completely new tune you must ensure that you are only running E85 in the tank when using our E85 tunes. When you are ready to change back to your pump gas tune you are required to use our "Fuel Drain" tune to completely drain all of the E85 out of your tank and run pump gas through the system to flush out any remaining E85 before switching tunes and running your vehicle. This tune will allow you to have the fuel pump prime without turning off to drain the gas from the vehicle without turning the car on. Failing to follow this procedure will result in a poor running vehicle.
Have more questions? Submit a request
Recently viewed articles
I just installed new injectors. Do I need a tune?
I just installed new coil packs/coil-on plugs. Do I need a tune?
I just installed Shorty Headers. Do I need a tune?
What gains can I see?
Do you offer a Ghost Cam Tune?
Related articles
What type of fuel do you tune for?
How to Datalog with the Bama/SCT X4 SF4
What to do if a dealer/repair shop is going to re-flash my PCM?
How do I datalog my vehicle?
s197
2007-2009 Mustang GT/CS
Nov 29, 2015 03:17 PM
IronAli
Tire and Wheel Tech
Oct 8, 2015 01:00 AM
irobles
1994-2004 V-8
Sep 20, 2015 04:30 PM
