draglite and nitrous question
Does anyone know if 15x10 draglites with 5.5 back spacing will fit on the rear of an 07 mustang. I already know I'm gonna have to use a rear sway bar relocation kit, I'm just wondering if it will fit with that back spacing or if Im gonna have to get some spacers. I'm also curious if there are many people running a zex kit and a 125 shot with a stock bottom end, just wondering if it will hold up.
If those are standard Draglites (i.e., non-XPs), you will have issues with the calipers. And even without spacers, they will stick out past the fender lip about 1.5". So, once you add spacers you're probably looking at between 2"-3" outside. Oh, and you'll most likely need to get longer studs as well.
does weld racing still make those? I can't find them on their website or on jegs? I was hoping to run the same slicks on two different vehicles. I'm trying to get some parts together for the mega ford weekend at mission raceway in September. If I was to put in a gt500 fuel pump would that work then? and would the bottom end still be fine? Thanks for the help guys!
![](http://www.2005stang.com/gallery/albums/userpics/10330/tn_med_IMG_8650sh.jpg)
![](http://www.2005stang.com/gallery/albums/userpics/10330/tn_med_IMG_1854sh.jpg)
![](http://www.2005stang.com/gallery/albums/userpics/10330/IMG_3031sh.jpg)
The stock bottom end will do fine with the 125 shot as long as you:
1) run the Ht0 plugs, you can retain the stock gap of .045--I didn't gap mine down to .035 until I ran the 150 shot
2) run the best gas you can--cheap insurance for the plugs and pistons. I used to run straight 100 octane on the 150 shot.
3) confirm your a/f on the dyno or wideband (if you have one). To get a 11.5/1 air fuel ratio I had to run a fuel jet .003 larger then the table called for.
4) I would also have your tuner tune for the 125 shot, and monitor the knock sensors to adjust timing accordingly.
5) fuel system upgrade of some kind--I used a BAP.
Below are some pics I took when I tore down my motor after 60K miles and about 175 nitrous passes at the track. Notice how thin the top of the piston is to the first ring-land. That is why you should use the best gas you can get so your pistons survive.
Well thanks to a BAP almost anything is possible on the stock pump. So saying you can do X on the stock pump really doesn't mean anything and can easily be misinterpreted. That's why I've been careful and have been talking about fuel SYSTEMS. You could really consider a BAP to not be a stock fuel pump...
I've been searching around like crazy and found a used set of rears thats 15x8 with 4.5 bs or I found a new set thats 15x10 with 5.5 bs which I know I can swap between both my vehicles.
Stock is 31-spline.
