which drag wheels?
Old Jul 4, 2006 | 03:42 PM
Machine's Avatar
which drag wheels?
okay, so a while back, I bought some stock 16's from a pre-05 stang and mounted some M/T ET Streets to them. it worked well, but I'm wondering if there is a 16in drag wheel out there that I can switch the stock wheels with...
also, wondernig what size drag wheel to go with up front....
any of you drag gurus out there know the answer...? I did a search, but couldnt find the answer...
Old Jul 4, 2006 | 06:52 PM
spyder7724's Avatar
weld racing makes a 17" draglite wheel now for our cars. summit should have them in stock. the fronts are 17x5" and hoosier is the only skinny front that is avaiable for them. rear are 17x9? there are plenty of tires choices for them. this will allow you to just install the wheels without any other mods. other wise going to 15" wheels you will need the bmr sway bar relocation bracket on the rear and also you would have to go with someone like bogart who makes a special wheel just for the 05-up. i have 15" bogarts 3.5" front and 10" rears. i love them!
Old Jul 4, 2006 | 09:46 PM
Machine's Avatar
appreciate the help, but I have already purchased 16" Et Streets which are mounted on a stock v6 rim, so I think I'd have to go with the same size drag wheel...
Fred_Garvin
Sep 17, 2015 04:10 PM
YepItsGreen
Sep 13, 2015 12:32 AM
Cdvision
Sep 5, 2015 05:22 PM
