Drag racing automatic launch question.
Old 6/2/07 | 08:54 PM
ren274u's Avatar
its the same thing as holding the break pedal down. thats what i dont get.
Old 6/3/07 | 01:16 PM
atomic_il's Avatar
Originally Posted by enitalp
I have a linelock in front of course for burn my new slick, but i think he's thinking about using a linelock for the rear for staging.
that's called a brake pedal
Old 6/3/07 | 02:13 PM
Mongoose's Avatar
What you don't get is the line lock only locks the front brakes.
Old 6/3/07 | 03:52 PM
ren274u's Avatar
I was refering to the post above it. Im trying to figure out why the guy thinks that line locks will benefit a higherstall torque coverter, other than the obvious fact of heating the tires up easier.
Old 6/3/07 | 06:25 PM
Sharky's Avatar
So why could you not use a line lock with a torque converter???
I am afraid i have thought about your question and don't quite get it either.
Our cars have torque converters from the factory, just not as hard core as a TCI.
But I am quite sure some of the big boys bang against their TC by using a line lock to help preload the drivetrain??
Am I wrong?
If I am not mistaken, many NHRA'ers use a launch controller. Effectively locking the front wheels while allowing them to max the drivetrain before the car moves an inch.
Old 6/4/07 | 02:03 PM
uberPony's Avatar
professional racers use a trans-brake to pre-load the drivetrain and then release it. Line locks are for heating the tires. If you used them at the line you would have no brakes on the rear wheels. So instead of pre-loading you would be sitting with front brakes locked and spinning the rears waiting for the green.
TCI converter is a little better than stock for launching these autos. The problem with them is they are just made from the stock OEM comnverters. You should really buy a better converter. There are better converters from Performance Automatic and Level 10 out there.
Old 6/4/07 | 04:37 PM
Sharky's Avatar
Now I know,
And knowing is half the battle.
Old 6/5/07 | 11:51 AM
Cowtown's Avatar
I feel like I just watched an NBC commerical.
50Cal
9/16/15 03:54 PM
Fernando.4ohh
9/10/15 03:35 PM
Omegaprime92
1994-2004 V-8
9/8/15 08:53 AM
Cdvision
9/5/15 05:22 PM
Quick Reply: Drag racing automatic launch question.
