do axle backs really give anymore hp? anyone dyno
Old Jun 11, 2005 | 07:55 PM
elvism's Avatar
stock and then test w/ new axle back and see any difference in dyno #'s?
Old Jun 11, 2005 | 07:56 PM
Dan's Avatar
Dan
Do You Remember Me?
I think the Borla axle back was tested to give a 6rwhp gain based on info given by the Magnaflow representative here.
Old Jun 11, 2005 | 10:49 PM
MaverickMLFD371's Avatar
im going sometime this week mike to the dyno and see what the flowmasters do.....
Old Jun 12, 2005 | 05:09 AM
tmcolegr's Avatar
My MagnaFlow Axleback mufflers did not increase RWHP.
Old Jun 12, 2005 | 08:20 AM
fin1's Avatar
Agreed. The performance shop I use didn't see any gain when they tested. Even the x-pipe replacement produced minimal gains. For me, the cost didn't justify the hp gains for anything after the headers. I went with the axle back for looks and sound.
Old Jun 12, 2005 | 10:29 AM
wild stray's Avatar
Nothing measurable from JBA axlebacks and same with Magnaflow X pipe with high flow cats.
Paul
Old Jun 12, 2005 | 10:32 AM
adrenalin's Avatar
If i remember correctly, some axle back kits resulted in a loss of hp.
Old Jun 12, 2005 | 10:22 PM
Dan's Avatar
Dan
Do You Remember Me?
Flowmaster's kit I believe resulted in a small loss in hp. This may be corrected now, I have no idea though?
Old Jun 12, 2005 | 11:18 PM
LordBritish's Avatar
Well, i won't be going with Flows if they lose HP.
Old Jun 13, 2005 | 06:31 AM
gotmy05's Avatar
SLP Loudmouths give some extra low end torque. I never put it on the dyno so I don't know the #'s but you can feel it.
Old Jun 13, 2005 | 06:34 AM
as I said in previous posts, from Flowmaster, they said that not resetting your computer will result in loss of power. When I installed mine and let the computer reset, I noticed a def increase, and when i go to the dyno this week, I'll know for sure and I will post the dyno sheets
Old Jun 13, 2005 | 07:17 AM
dallasw77's Avatar
Paul,
Are you doing a before and after dyno? or did you dyno without your Flows already?
Thanks!
Old Jun 13, 2005 | 09:28 AM
acadian's Avatar
I never dyno'ed my Magnaflow axleback, but I could swear I felt a difference after installing them. Of course, that could be my imagination. Maybe since it got louder, my mind related that with it getting faster. But you don't buy an axleback for performance. You buy it for sound and for looks. One of the ugliest things on the GT IMO is the factory tips.
Old Jun 13, 2005 | 09:36 AM
freyke's Avatar
The computer reset is easy? No?... Simply remove the Negative battery terminal and let sit for 20min?... Ehhh?
Old Jun 13, 2005 | 09:37 AM
freyke's Avatar
Old Jun 13, 2005 | 09:47 AM
acadian's Avatar
I think you only need to let it sit for 5 minutes. But it's as easy as diconnecting the negative from the battery.
Old Jun 13, 2005 | 09:49 AM
i did a stock run already, i installed the K&N aircharger, so I know Im guarantee 15 horses right there, so whatever I get from the new dyno number and subtract the stock pull and 15 and get the total for the flowmasters. I disconnected the negative battery cable for at least an hr cause thats how long it took to get the exhaust on.....
Old Jun 13, 2005 | 09:52 AM
freyke's Avatar
I'm guessing if it's anything like my 89 LX 5.0, then just put the terminal back on and let it idle for 5 minutes to "find itself" so to speak...
Old Jun 13, 2005 | 10:10 AM
jwgroovin's Avatar
What is this "computer reset"? What exactly is getting reset? I have a C&L intake that required a downloaded tune with a Diablosport Predator, and MAC axlebacks. Will this "reset" wipe out my tune or change the parameters that the tune depends on?
John
Old Jun 13, 2005 | 12:29 PM
acadian's Avatar
Disconnecting the battery will not disable your tune. I believe it just lets the computer reset certain parameters and helps the car to recognize minor modifications that do not require a tune, like an axleback or a new air filter. It's like rebooting you home PC after installing a game or program. It's not always necessary, but will usually help to make that game or program run better.
It doesn't exactly work that way. Adding individual modifications together are not going to get you their individual gains. If you add the K&N seperately, it might get you 15HP. An axleback may get you 5HP, pulleys 10HP, and some headers 15HP added seperately. If you add them all together, you aren't going to get 45HP. More like 35-40. So, with that said, your calculation of subtracting the 15HP will not be completely accurate. Unless you can do an actual dyno before and after adding only the axleback, I wouldn't go around saying that the exhaust added a certain amount of HP based on the K&N. And to be honest, with a gain that will be very minimal like with an axleback, the dyno numbers still won't be 100% accurate unless the car is the exact same temperature and under the exact same conditions during both runs.
Andy11859
Which is Better
Sep 10, 2015 12:07 PM
glo106
Aug 11, 2015 08:29 AM
Kaleb LaCoste
Aug 6, 2015 06:57 AM
