Different Grade Oil for Supercharged Engine?
Old Oct 8, 2005 | 11:30 AM
thestoogeo's Avatar
I am going to be installing an ATI ProCharger on my 2006 Mustang GT. Would it be ok to run 5W30 while the engine is stock? What about when it's super-charged? Would it be better to stick with the 5W20 from the owners manual? What about 10W40? Thanks for your input.
Jon
:drive:
Old Oct 16, 2005 | 06:11 PM
thestoogeo's Avatar
I decided to go with Royal Purple 5w30.
Jon
Old Oct 17, 2005 | 10:24 AM
True_HP's Avatar
Good choice....when you are pushing the limits of your stock engine synthetic is the way to go...
Old Oct 17, 2005 | 01:07 PM
clintoris's Avatar
The way I understand it is that you don't want to go to a heavier oil, because the tollerances are so tight on these engines, and you may not get adequate oiling in the heads.... I was told one time that 10W40 would leave them dry.... anyone else have anything to say that would clear this up?
and as for supercharged motors.... I can't speak to that.
Old Oct 17, 2005 | 01:53 PM
JeffreyDJ's Avatar
Am I being silly asking why you'd want to change? Why would you want to go with a thicker oil in a new engine?
I don't have a s197, but I use AMSOIL 5w20 in my Mach.
Old Oct 20, 2005 | 10:30 PM
thestoogeo's Avatar
I chose the operating temp weight of 30 vs 20 because I expect that a supercharged engine will run at a higher temperature than the normal engine. In Western Colorado we see temps ranging from 0 F in the winter to 100 F in the summer.
See also:
Engine Oil Debate
Feb 10, 2017 07:12 PM
dblhelx
Oct 6, 2015 08:08 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
JonathonK
Sep 19, 2015 03:19 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
