Did I ruin my Rear Brake Pistons?
So I decided to change my rotors to the drilled and slotted Rotorpros and purchased front and rear Hawk pads to compliment. Now I am no professional but I can turn a wrench, so I tried to do the install myself.
Front rotor and pad install went smoothly. Had to pry the front pistons open to fit the new bulkier pads but everything went on without a hitch.
Now here is where I really goofed. I now know after an hour of messing with the rear pads and doing more research that they require a special tool to retract the piston. I did try prying on both the passenger and drivers side rear to get them to release before I knew about the tool needed. I got the special tool and began to turn clockwise...after endless turning it looks as though the piston does not want to retract. It turns but doesnt look to be going into the caliper. I Tried the other side and the same results.
How do I know if I have ruined the pistons? I dont think I pryed too much on it...but I dont know how much they take before they give out. Any suggestions? Ive quit for the night...but going to try and re-install the stock pads and see if the caliper itself is still functioning tomorrow (well technically this morning). I feel like the dumbest person in the world right now...chalking this one up to a learning experience. Any help would be very much appreciated guys... lets get those Rear hawk pads in there and working
You have to turn and apply preasure at the same time to get the caliper to retrac. Check for leaks? When you install the new parts and reasemble press the brake pedal to see if the caliper move out. You may want to open the bleeder so you don't push any drirt back to the A,B,S unit or master cylender!
What tool is there besides the universal cube tool?
http://images.google.com/imgres?imgu...F_enUS272US273
free rental at autozone
Thanks Glenn!
Thanks guys... I used the tool Glenn suggested and walla...pistons compressed...also I opened the bleed valve while compressing. Rotors and Pads are on and broken in!! Thanks all for your help
I just did mine a couple of weeks ago. That little universal cube is a POS doesnt work. Just go to Autozone or most auto stores have free rental tools which work great on the rear disc brake cars. Thats what I did. The tools at Advanced Auto Parts were a little nicer than the ones at Autozone I went to both.
Twist and push thats the key also I found it works much easier if you have the BLEEDER screw LOOSE while your twisting and pushing. Push hard and it will go in dont expect to much retraction though. Make sure after you flush the system with clean brake fluid check for leaks. While your at it might as well paint the calipers.
Well guys I promised pics!! Here are a few of the car and then of the wheels with the new Rotors and pads
The Rotors came Black Zinc coated
Old Brake Pad Hawk Brake Pad
I have the G2 Black Caliper Paint... I just need a day to get it done and allow it to dry. Thanks again for everyones help..this is a great site!!
Evil_Capri
Motorsports
Sep 11, 2015 08:04 PM
Sep 8, 2015 10:45 AM
