Delete Plates HELP NEEDED!!!
Yes, that is correct. You need a custom tune from Bamachips, Brenspeed or some other reputable shop. Without it you will actually loose power. I wouldn't even drive the car until you get the proper tune for the CMCV delete plates.
I could be wrong, but I think I remember reading that on the Predators, there is an option for deleting the plates BUT that option has to be turned on when it is setup. If that's true, maybe that's what you're thinking of Sharky. If you don't see it as an option, then these other guys are right- you need to get a tune for it.
Diablo Sport used my car to work out the tune for the CM plates with the Steeda CAI and I assume they used my results for other CAI's too. You need a special tune that accounts for the plates , there is no option you can set ...
Not true ! before I converted my X-CAL II 9415 Strategy Flash canned tuner into a standard 9400 custom tuner..their was an option in the end user adjustability menu for CMCV delete in which to select from..
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
