D-Spec tuning instructions?
Old Dec 14, 2007 | 04:09 PM
FinlayZJ's Avatar
I just got some D-Specs, but don't have the instructions and tips on how to set them? Does anyone have an extra copy, or electronic copy I can have? Thanks.
Old Dec 14, 2007 | 07:22 PM
scramblr's Avatar
They instructions are worthless. At the top of each shock/strut, there's a cap. Unscrew the cap off and take the supplied key and close the valve, i.e, turn clockwise until it stops, full hard. Then, for every counterclockwise full turn, you've opened it one full turn. You can go up to 7
turns, full soft. Now depending on your driving conditions, set to your satisfaction. I run mine 3 upfront and 3.5 in the rear since my roads are fairly decent. The roads sucked where I used to live, so I was at 5 and 6. Now, when I go on long trips, I set them to 6 on all four corners to have a comfortable ride. It's all on how you want your ride to feel, that's why they're so great. Hope this helps...
Old Dec 14, 2007 | 07:51 PM
65sohc's Avatar
I think Tokico recommends starting at 5 turns from full hard which is pretty close to how the stock shocks ride. I'd say 1/4 turn is probably the smallest increment that will make a noticeable change.
Old Dec 16, 2007 | 08:57 PM
relayagent's Avatar
i've got mine on 5 away from F front and back.. whats the thinking in setting the rear softer than the front? performance, preference, traction??
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
