d.o.t. slicks
Old May 2, 2005 | 05:36 PM
onebadgsx's Avatar
whats size slicks are you guys running. i am looking for a non-radial dot slick, like MT et street. i know they make a 26x11.50x17. will these fit? will a 16" wheel fit, what size slicks on these.
Old May 2, 2005 | 07:24 PM
dhof303's Avatar
The slicks that fit the 17" wheel will fit, 169stang uses them and I have ordered them along with a second set of rear wheels. Here is a link to some moderately priced ones but I would suggest having a local tire shop order them as the tax will be less than shipping as long as they don't make you pay for shipping. I got them ordered and installed for $195.00 each with tubes.
http://store.summitracing.com/default.asp?...49&autoview=sku
Old May 2, 2005 | 07:59 PM
169stang's Avatar
I burned those slicks up pretty quick and I ONLY used them at the strip. I went to the ET Street radials this round. The radials are safer to ride on the street with. If you plan on daily driving, I wouldn't recommend the non-radials. They are a bit scary while haulin down the highway. So far, I feel they hook better than the non-radials. My 60' is better with them atleast. Either way, you'll be happy when you run on them. One other observation...when you let the air down on the non-radials, you'll sway when you let off the gas. I've run them at 14psi and it swayed so bad, I felt like it was going to get sideways. I always ran them at 18psi, which took away the real bad sway feeling. The radials don't sway nearly as much. I bought a second set of bullitts (17x9) from MMR. http://mustangracing.com/ Very inexpensive wheels. I also had to screw my wheels to the tires. I marked the wheels and tires and the tires were moving about 1 inch per run. Some here say that isn't really important or imperative. I felt better knowing that the tires were not going to blow off the bead on a run with the screws.
Old May 2, 2005 | 09:37 PM
cdemot02's Avatar
I am going to put street racing tires on my stock rims for when I go to the track. Found them as cheap as 110 bucks...
robjh22
Dec 14, 2015 08:41 AM
FromZto5
Oct 2, 2015 10:07 AM
RCW
05-09 Exterior Modifications
Aug 31, 2005 11:46 PM
Vegasjay
May 29, 2005 10:25 AM
dhof303
15
Apr 19, 2005 07:11 AM
